Lnf P0087 and P0089?
Old Feb 26, 2016 | 05:08 PM
aebooth6's Avatar
While driving on the Expressway I get the "engine power reduced" on the dtc. I can't drive over 40-45 and gets up to speed slow.
My question is... What steps do I take to find out how to fix this problem?
Has this happened to you? What was the problem?
Help please
Old Feb 26, 2016 | 05:29 PM
Well seems like your p0087 is fuel related problem have you checked the hpfp? Connections and all that other stuff?
Old Feb 26, 2016 | 06:55 PM
aebooth6's Avatar
I have idea what to look for or where the hpfp is at. Help
Old Feb 27, 2016 | 11:05 AM
aebooth6's Avatar
Old Feb 28, 2016 | 01:21 PM
aebooth6's Avatar
Something I can fix? Or just take it to a shop?
Old Feb 28, 2016 | 04:07 PM
no_ss's Avatar
In my photo the circle looking thing above the yellow tag next to the charge pipe with the plug going into it is the HPFP. They usually have a black foam covering over them held on by a black metal plate.
Old Feb 28, 2016 | 04:08 PM
no_ss's Avatar
And I believe the torque spec for the 2 bolts is 10ft lbs of torque
Old Feb 29, 2016 | 10:49 AM
umrdyldo's Avatar
I had these codes and ENG PWR Reduced.
The giant wire loom that is running to the right of the hpfp had come undone and was rubbing wires on the Hpfp. I put the loom back over the wires and then put a piece of foam around it to keep it from rubbing on the frame of the fuel pump. This was reported by several people.
If that doesn't fix this issue, then hpfp is probably next.
Old Feb 29, 2016 | 02:19 PM
aebooth6's Avatar
I guess I will have to check those wires when I get home. So it's the big wire block thing that comes undone?
Old Feb 29, 2016 | 05:20 PM
umrdyldo's Avatar
Right where my finger is the wire loom to the right will rub on the metal frame and the left. When i do oil changes the wire loom will move a little and start the headache over.
With that said, this may not be your issue but please check it before moving to replace pump.
Old Feb 29, 2016 | 06:35 PM
aebooth6's Avatar
Awesome thanks for doing that for me
Old Mar 3, 2016 | 02:34 PM
aebooth6's Avatar
Couldn't find the problem so I took it to the shop. They wanted to charge me $900 for the pump including install. I said **** that and ordered one from zzp for $200. Damn scammers
Old Mar 3, 2016 | 02:55 PM
umrdyldo's Avatar
I am not sure I have seen a write up on how to install these.
Let us know how it goes and do a write up if you can.
ssyn
Mar 8, 2016 06:56 AM
Bigslim
Mar 1, 2016 03:07 PM
Karnage
Feb 24, 2016 09:00 AM
Badbren_ss
Feb 20, 2016 04:49 PM
Luisitogomez
Feb 19, 2016 11:04 PM
