Low Hanging Exhaust fix
Old Oct 3, 2006 | 10:11 AM
YellowLT's Avatar
So ever since I installed my Magnaflow system it hangs down kinda low and scrapes ocassionaly, until now. I was on JBP and they now have Poly Exhaust hangers woot woot.
75 for the set not to shabby.
http://www.jbodyperformance.com/new/...catName=JP0964
Old Oct 3, 2006 | 12:18 PM
redlineblueline's Avatar
Those will stretch a whole bit and make it lower you'll need to wrap them in a hose clamp or something to keep it where it is supposed to be.
Old Oct 3, 2006 | 01:42 PM
mkulrey13's Avatar
my dc sports uses the stock rubber thingys... it sticks like the stock one does... or maybe im not thinking the same thing.
Old Oct 3, 2006 | 05:53 PM
YellowLT's Avatar
My Middle section hangs really low and ocassionally scrapes going over bumps and stuff
Old Oct 3, 2006 | 06:03 PM
Beck's Avatar
cant you find them somewhere cheaper for less than 75? that seems expensive for hangers....
Old Oct 3, 2006 | 06:05 PM
wdsoccer's Avatar
i got some at auto zone for $3 a piece. not a name brand or anything but it does the job
Old Oct 3, 2006 | 06:45 PM
Beck's Avatar
yea i was thinking something along that line 75 for a set is way too much for something you wont even see, and wont even make any noticable difference in performance...
Old Oct 3, 2006 | 06:59 PM
Rangerondubz's Avatar
WOW that is a rape
Old Apr 10, 2009 | 09:59 PM
SSinPA's Avatar
have any solutions for this?
[IMG][/IMG]
and this?
and this leak. It is leaking her and on the top of that joint.
Old Apr 10, 2009 | 10:27 PM
HunterKiller89's Avatar
you realize those poly hangers wont raise your exhaust at all? They just keep it from swinging around during tunrs, which helps contribute to overflexing the flex joint part, which will reak the exhaust. It will still be at the same height tho
Old Apr 12, 2009 | 01:38 AM
Sp0rkeh's Avatar
hey SSinPA what length is that resonator? hows it sound? just curious
thanks
Old Apr 12, 2009 | 01:41 AM
slick54's Avatar
70 bucks for a hanger just get the exhaust strap they sell at autozone its like 3 bucks did the job for me and it tucked it really nice
Old Apr 12, 2009 | 09:00 PM
SSinPA's Avatar
the resonator is the one that comes with the magnaflow catback it sounds pretty good but i have a leak so as soon as it is fixed i will know for sure.
Old Apr 12, 2009 | 09:46 PM
rukkee's Avatar
2 bolt flanges suck , they tend to bend in the ears and cause a leak. U could try to double gasket the DP to resonator flange but it doesn't always work.
Old Apr 15, 2009 | 10:46 PM
SSinPA's Avatar
so there isn't a really good fix for it? Am i supposed to just live with a leaky exhaust.
Old Apr 15, 2009 | 10:53 PM
nikebaseballx00's Avatar
for 75, i can have mine cut and welded back together.......
Old Apr 15, 2009 | 10:56 PM
SSinPA's Avatar
where would you cut and weld?
Old Apr 15, 2009 | 10:57 PM
OBZ's Avatar
OBZ
Bro I told you like a month ago just to get a new gasket.. Have you done that yet?
Old Apr 15, 2009 | 10:58 PM
07blackg5's Avatar
Slobodan Milošević
i just did like the second poster and wrapped my stock one in a hose clamp
Old Apr 15, 2009 | 10:59 PM
before the spot where it hangs low, then they would just twist it upward and reweld it
then adjust the hangers so it hangs fine
Old Apr 15, 2009 | 11:19 PM
SSinPA's Avatar
yes i got a new thicker gasket but it didn't fix the leak.
Old Apr 20, 2009 | 12:21 PM
saunders1986's Avatar
my muffler tip sits to the left alittle to far, i find myself kicking my muffler back in place,.... lol any fixes?
Old Apr 20, 2009 | 05:55 PM
07blackSC's Avatar
My exhaust used to hang low too and I'm lowered so i scrape here and there too. My fix- Use a coat hanger and wrap it around the two metal brackets a few times and cut off the extra, but leave the rubber hanger on there too. Hope this helps!
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
TedSS
26
Oct 10, 2015 04:30 PM
dieGone
Oct 1, 2015 06:27 PM
Slick_Nick
Sep 28, 2015 09:15 PM
