Manifolds
Manifolds
I had a question.......Im ditching my Sc setup and going with a turbo setup but my question is will the Stock intake manifold from the 2.2 bolt up to mine and if so will it be ok to use for my setup? Im selling my SC intake manifold with the SC and will need intake manifold to use for my Turbo setup...
INTAKE manifold...........
k ima try to clear this up. My main question is if i build a turbo kit using the 2.2 INTAKE manifold on my 2.0 will it work? A.K.A. "will it bolt up, are there the same sensors?" etc...
Last edited by Scott.Florschuetz; Jul 20, 2008 at 09:41 PM. Reason: Automerged Doublepost
use either the 2.4 mani.. hahn racecraft intake mani, or gmpp intake many.. or the saturn motorsports turbo intake mani should work.. do not .. i repeat DO NOT> use the 2.2 mani you'll blow that thing to bits lol
LOL ..thanks guys...i should be building as early as next month. Im still waiting on more words from hahn on some parts but i cant wait to see the results. Once again guys thank youfor your help.
