my turn signal
Old May 24, 2008 | 06:22 PM
Vetteman99's Avatar
my turn signal
have any of you had it where your turn signals started clicking at a very fast rate of speed. Well my right hand turn signal is ticking like its on steroids any way to fix it without taking it to a dealer?
Old May 24, 2008 | 07:18 PM
Coblasts's Avatar
One of your signal bulbs being burnt out is usually the cause !
Old May 24, 2008 | 07:20 PM
wombat's Avatar
turn your signal on.
get out of the car.
walk to the front to make sure that one is blinking.
walk to the back to make sure that one is blinking.
replace the one that's not blinking.
grab a seat and open a beer.
Old May 24, 2008 | 07:28 PM
madmark's Avatar
bulb is burnt out =\
Old May 25, 2008 | 01:46 AM
GTO 1's Avatar
Turn Signal Flasher (if not a bulb)
GTO 1
Old May 25, 2008 | 02:02 AM
kkanowitz's Avatar
GTO 1
Im not sure, but do we even have flashers? The clicking sound is digital. (05,06 from speaker in gauges, 07^ is from OEM headunit)
Old May 25, 2008 | 02:11 AM
spencer's Avatar
my right signal just started doing that a few days ago too. i figured out the light was out but i was gonna post this same question because i wanted to make sure nothing else is wrong too
Old May 25, 2008 | 02:24 AM
TheCaptain's Avatar
Burnt bulb. Circle check!
Old May 26, 2008 | 10:59 AM
Vetteman99's Avatar
both bulbs are working fine now and there is no more speed clicking. So whale going on I didn't change the bulbs yet?
Old May 26, 2008 | 11:01 AM
CobaltVenomSS's Avatar
mine did that too...they would work for a day then they wouldnt...just change it and it wont happen again....but i guess u dont know what bulb it is now lol
Old May 26, 2008 | 12:36 PM
EmperorJJ1's Avatar
lol im already so used to it i dont know what its like to have flashers that aren't crazy fast... i have led amber bulbs up front and im not shelling out the cash for a resistor to fix it
Old May 26, 2008 | 12:48 PM
Stouffer's Avatar
You can get four resistors for like 20 bucs if you feel like fixing it. I couldn't stand the fast blinking.
Old May 26, 2008 | 12:51 PM
ColeJJones's Avatar
Bannned
i had the same problem too bud. it was my rear right taillight. it works but sometimes it didnt and it clicked really fast when i hit the turn signal. it was a connection issue. i got a zip tie and and tightened the hell out of the harness that comes off the tail light
Old May 26, 2008 | 08:03 PM
EmperorJJ1's Avatar
ya i know i really could care less now thou. lol at first i didnt like it and was gonna change it but after being lazy for a few months its normal to me now
Old May 26, 2008 | 08:06 PM
silentgarth's Avatar
Fast clicking = rear bulb
solid light = front bulb
Old Jun 2, 2008 | 01:18 PM
Vetteman99's Avatar
thanks i want the led lights now but where do i put the resistors
Old Jun 2, 2008 | 02:36 PM
NCC-2000's Avatar
You tap into the wire that would normally go to the bulb, I forget the colors at the moment, but in the front you wire it up to the signal wire (not the parking light wire) and a ground, and the rear goes on the brake light wire and ground. I got off lucky with my lights, cause my tail lights cam prewired with a little resistor box, so I only had to put these things on my front signals.
By the way, Cobalts only get a fast clicking if a bulb is out. The solid light thing was common on older cars that still used thermal flashers. My Sunbird did this until I replaced the flasher with a non-thermal one.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
roth
Sep 26, 2015 12:16 PM
