My wheel almost fell off!!! Wtf!!!
Old Jul 23, 2009 | 08:16 PM
Jpitts210's Avatar
so pretty much FML!
basically three studs broke, AT ONE TIME!!!!
i'll tell the rest of the story when I get out of class tonight at 9:50
EDIT:::
So here is what happend, i'm driving and as I turn onto an access road i notice really bad thumping and then right before I get onto the highway I can literally feel the tire wobbling back and forth so I pulled to somewhere safe asap and get out like WTF just happend!!!??? the wheel is hanging on by one lug nut and the top is angled out way way far. I put on after market rims like 3 months ago and know I didnt over/under torque them so I dont know why it happend. I was due for an alignment and tire balance but idk. Scary ****, my car was so so so close to being screwed up something bad.
68 bucks for the tow and I pick it up at 8am tomorrow, lets hope it doesnt cost an arm and a leg. Pretty sure no other damage was caused.
side note: I just thought about this, I had pretty noticeable vibrations when braking which I thought was just do to my rotors needing to be machined. Could that have possibly vibrated the lugs loose causing the studs to eventually give way???
Old Jul 23, 2009 | 08:17 PM
jonxxxedge1's Avatar
how?!
Mnatvyc1223's Avatar
shitt it's a good thing u werent running rotas, they'd have broke too!
on another note, did you over torque your nuts? ha
Old Jul 23, 2009 | 09:23 PM
WickedSS2005's Avatar
This EXACT thing happened to my wife's car, passenger front wheel. Her's is a 2006 LT coupe. Just bought her rims the month before and now only have 3... and they are discontinued.... I've put on plenty of rims and never had issues. I swap mine around 4 times a year with rotation and winter/summer sets. Always torqued to spec
Old Jul 23, 2009 | 09:32 PM
383_Stroker's Avatar
quit leaving the lugs loose
Old Jul 23, 2009 | 09:34 PM
occsdude's Avatar
check and recheck
Old Jul 23, 2009 | 09:35 PM
I checked and rechecked after 1k miles
Old Jul 23, 2009 | 09:40 PM
Brian MP5T's Avatar
Someone needs a torque wrench..
Too much of a good thing is bad... It brakes Cheap Studs..
Old Jul 23, 2009 | 09:42 PM
QuickShift's Avatar
I had this happened to an old Contour I used to have...Torqued to spec??
Old Jul 23, 2009 | 09:47 PM
ZeeBee's Avatar
most of the time its due to cheap aftermarket lugs, i changed back to stock lugs after 3 studs broke, each a different rim, since the swap i have been good/
Old Jul 23, 2009 | 11:52 PM
Snakes709's Avatar
seen that happen before to a riced out sunfire...dude must have spent like $4000 in a gay body kit).. Me and my friends were just chilling and we hear a grinding noise and look over...sunfire sliding down the road with a front passenger wheel bouncing past him. Ran over and talked to him...he said him and his friend just rotated the tires. Asked him what torque specs did he use...he said he wasnt sure, they used a air gun and just hit them as tight as they can go....broke all the studs off. Recked the rotor, control arm, wheel, body kit.
Old Jul 23, 2009 | 11:55 PM
madmark's Avatar
torque to tight
ls studs and nuts are really cheap probably just expanded under heat and backed themselfs off......
thats my story and im sticking to it
Old Jul 23, 2009 | 11:58 PM
ZeeBee's Avatar
i doubt Gm as cheap as they can be, would cut cost on crucial parts
Old Jul 24, 2009 | 12:04 AM
souchak2112's Avatar
im gettin Motegi SP10 rims tm. (hopefully) Jack Williams is puttin them on for me. If something like this happens, they would be responsible right? How often should I check them? should I get different lugs or is Motegi/AM Racing lugs good?
Old Jul 24, 2009 | 12:09 AM
ZeeBee's Avatar
its not the lugs its, using the correct torque setting, and avoid after market lugnuts.
Old Jul 24, 2009 | 12:26 AM
im gettin Motegi SP10 rims tm. (hopefully) Jack Williams is puttin them on for me. If something like this happens, they would be responsible right? How often should I check them? should I get different lugs or fo Motegi/AM Racing supply good lugs?
Old Jul 24, 2009 | 12:37 AM
outtamymind's Avatar
i've done thousands of rims from steelies to 24's and never had a wheel even come close to falling off. and i use a torque stick on most of them and if you are using a torque wrench, get it checked from time to time to ensure it is still accurate.
Old Jul 24, 2009 | 12:41 AM
scottyguy401's Avatar
Torque those beezy's to 100 lbs
Old Jul 24, 2009 | 01:23 AM
Jpitts210's Avatar
hmmm i wonder if that could have been the cause, I had after market key lugs but I have to because of my rims, stock lugs are too thick to fit in the holes.
Old Jul 24, 2009 | 01:34 AM
Sharkey's Avatar
are you running the hubcentric rings??? if not, thats your problem right there. most vehicles are designed for the wheel to be centered by the hub, not whe wheel nuts. aftermarket rims are usualy a larger size and with the plastic hub rings will adapt to fit different vehicles. without the rings there is nothing to center the wheels, and the studs take a lot of the load.
Old Jul 24, 2009 | 11:42 AM
ferrucci86's Avatar
when i first got my rims they torqued them and told me to come back or retorque them myself after 25 miles. so take how you want.
Old Jul 24, 2009 | 12:43 PM
Jpitts210's Avatar
Ya I have the rings but there is a crack in that one. But it still seats properly and shouldn't be the problem
Update: thank god it only cost 60 bucks to fix and she's back on the road ready for something else to break lol. No other damage besides the studs thankfully and the shop couldn't tell exactly what caused it. Basically said it could have been any of the things you guys have been saying
Old Jul 24, 2009 | 04:47 PM
ZeeBee's Avatar
60!!! i did it in my garage for 2.00$ a stud
Old Jul 24, 2009 | 08:44 PM
Sharkey's Avatar
yes but a shop has to pay their overhead and charge labor. id guess about 1/2 hour labor, plus parts, shop supplies and taxes.
Old Jul 24, 2009 | 08:45 PM
cobaltchk06's Avatar
sucks to hear man! i definately know how ya feel.. that's my car in post 4.
my car was gone 2 weeks.. new fender, rotor and bunch of other little ****.. 4k in damage
lucky for you, you pulled off. mine came off WHILE i was driving down the highway!!
