Need information on A Arms
I replaced the strut before cause I thought that's what was wrong but it wasn't. I asked the seller if it was an they said yes it's the correct one. I'm going to be checking the knuckle today. I'm getting tired of pulling the same wheel off day after day. What is your measure for your wheel to center? So I can compare the two
i replaced that strut already I'm going to drop the engine cradle to get a better look at it something has to be off to cause a cv axle failure an yes i was looking at the cv axle in the picture an it does look really off looks like the knuckle was pulled out before i even put power to it.
weird. its going to be a process of elimination now.
Check:
-trans mounts
-engine mount
-intermediate shaft
-knuckle/hub
Also do a very detailed visual inspection of anything that looks weird underneath. Make sure the car is supported very well before crawling underneath
Check:
-trans mounts
-engine mount
-intermediate shaft
-knuckle/hub
Check:
-trans mounts
-engine mount
-intermediate shaft
-knuckle/hub
underneath
Check:
-trans mounts
-engine mount
-intermediate shaft
-knuckle/hub
underneath
#37
Check the upper engine mount on the passenger side. Usually a knuckle will break before it bends. When you installed the axle did you make sure it was seated all the way inside the intermediate shaft? Make sure there is no damage to the intermediate shaft bearing or bracket.
#38
#42
