New Sparkplugs?
New Sparkplugs?
I am about to hit 50k and i am not having any misfires so my dad told me new sparkplugs are not nessicary. I have read around and some people advise to change them at the 50k mark. input?
GM's recommendation, per the owner's manual, is to have the sparkplugs changed at 100,000 miles. There's a full breakdown of recommended service parameters starting on p. 397.
Hope this is helpful,
Sarah
GM Customer Service
Sarah
GM Customer Service
i just turned 50K and am on my 6th set or so. I change them every other oil change
i run the NGK 3787
Dude with a boosted and tuned car they do. Pull yours and see what they look like if you havent pulled them yet
correct i do them every other oil change.
at about 5K youre good. If you want then pull them just to check them out.
spark plugs last UP TO 100k miles under ideal conditions. Change em at 50k its time, they probably visible wear, and you wouod probably notice a bit of improved fuel economy. Change your air filter ans fuel filter if you have an external one while your at it.
They also say the auto trans never has to have a fluid change too...you believe that?
Also have a friend who works at a dealership telling me they F-ed up on the OLM on 3.6 motors so timing sets are getting trashed because people run the percent all the way down.
The biggest issue with the 3.6s is that people dont check the oil. SO the OLM says its okay to go 7-10k miles and people never check it during that time, which means it runs low, and accelerates oil wear, and the monitor cant calcualte for that, it always assumes a full crankcase. So they just shortened the OLM interval. now it never goes past 7500 on the 3.6 no matter what
