New Transmission Question
Old Mar 15, 2015 | 04:07 PM
  #51
aebooth6's Avatar
Originally Posted by slapbetcommissioner
S1 cams don't show allot of gains on the k04 mostly because the k04 can't flow much more air efficiently. The real power gain comes from the fuel lobe when you run out of fuel on your tune ie the e85 tune. Not so much airflow. E85 tune and fuel lobe upgrade alone would net very similar gains as the s1 cams with fuel lobe uograd (on the stix turbo)
Okay thank you. Then no s1 cams for me. Just the fuel lobe upgrade
  #52
slapbetcommissioner's Avatar
Originally Posted by aebooth6
Also what is the best setup of mounts? How about zzp engine billet mounts? $150
Powell has these
Rotated mounts from powell would be my reccomendation over just firmer inserted mounts.
Rotation changes the alignment of the axle to help with wheel hop (the trans killer)
Old Mar 15, 2015 | 04:14 PM
  #53
aebooth6's Avatar
Rotated mounts from powell would be my reccomendation over just firmer inserted mounts. Rotation changes the alignment of the axle to help with wheel hop (the trans killer)
Stage 1 or 2 rotated trans mounts from Powell?
Old Mar 15, 2015 | 05:01 PM
  #54
Stage 2 would he best performance but most vibration.
Both do a good job though
Old Mar 15, 2015 | 05:05 PM
  #55
aebooth6's Avatar
Stage 2 would he best performance but most vibration. Both do a good job though
I'll take a vibrating car anyday to stop wheel hop
Old Mar 15, 2015 | 05:22 PM
  #56
How do you keep the torque down?
With a boost ramp or a bigger, and subsequently slower spooling turbo.
Originally Posted by tuned08ss
Which just goes back to the fact u might as well stay k04 with an aggressive e85 tune.
Thats how you blow the trans lolol
Last edited by Slowbalt2000; Mar 15, 2015 at 05:22 PM. Reason: Automerged Doublepost
Old Mar 15, 2015 | 05:29 PM
  #57
aebooth6's Avatar
With a boost ramp or a bigger, and subsequently slower spooling turbo. Thats how you blow the trans lolol
Example of a slower spooling turbo?
Old Mar 15, 2015 | 06:06 PM
  #58
Devin86's Avatar
Stage 1 for lnf stage 2 for lsj these days. I think he might make a RACE/TRACK mount but no good for DD he said. Crazy vibes unless u are racer X everyday and dgaf lol😂
Old Mar 15, 2015 | 06:08 PM
  #59
Shanedude's Avatar
See my whole idea of going "big turbo" is out the window for this car. The trans is too much of a let down and why buy a quick spooling turbo if you're going to boost ramp it. In my area, having a k04 on 22.5 psi is plenty to beat most of the cars around town. Big turbos on the lnf just seem to be for dyno numbers. But in all honesty I feel all the "usable" power for the street can be accomplished with the stock turbo.
Now on the other hand, if u plan on track days or roll racing past 130 mph then yeah I would say a larger turbo is for you. Remember though this is just my opinion. Hope no one takes it to heart.
This.
Some people can hit 12's with GMS1. Some ZFR owners are still in the 13's or low 14's.
Old Mar 15, 2015 | 06:14 PM
  #60
S20g
S256et
Gt3076
Old Mar 15, 2015 | 07:24 PM
  #61
aebooth6's Avatar
Originally Posted by Devin86
Stage 1 for lnf stage 2 for lsj these days. I think he might make a RACE/TRACK mount but no good for DD he said. Crazy vibes unless u are racer X everyday and dgaf loldde02
I want them for a DD
Old Mar 15, 2015 | 07:26 PM
  #62
aebooth6's Avatar
S20g S256et Gt3076
Hmm I'll look into them. Which one is the best
Old Mar 15, 2015 | 07:34 PM
  #63
Devin86's Avatar
Then get stage 1 powell mounts it includes a spacer for the rear mount. Also get powell/ottp control arm bushings. I got mine in the mail right now lol I got th s1 mount but notice alittle wheel hop still looked and my cab is starting to tear on the driver side the other side isn't fair behind. Stock cabs are a big reason for wheel hop they are junk.
Old Mar 15, 2015 | 07:40 PM
  #64
Devin86's Avatar
Originally Posted by Shanedude
This.
I know right I die when modded tc's fail. Drive mod makes or brakes these cars. This dude in my town lost to cars running like mid 14's when hes on gms1 lol
Old Mar 15, 2015 | 07:44 PM
  #65
aebooth6's Avatar
The thing is I don't know how to install them and I know there is a how to on installing them
Old Mar 15, 2015 | 07:51 PM
  #66
Devin86's Avatar
The how to powell did makes it easy when ur under the car it's like 7 bolts. You losses the rear then only take out the stock front then tighten every thing up in order he says it in. I got the mounts tight the set the car on the ground when I tightened the motor mount down. Powell says to do this also. But I don't think that's in the how to.
Old Mar 15, 2015 | 07:53 PM
  #67
Wert842's Avatar
Don't do cams with the stock turbo imo. Fuel lobe mabe, it can go in stock cams as well, way cheaper then s1 cams with Fuel lobe. Get fully bolted and a good e85 tune. When ppl say get full bolt ons they mean get rid of the plastic sht.. Also a downpipe is way more flow the stock DP. U can still break other stuff then the trans that's like that's on the list to be worried about haha
Some cars when going full E can't handle it and that's when you need the cam. It all depends on the circumstances. It's not a guaranteed yes or no though. Definitely worth it when running Full E
Old Mar 15, 2015 | 07:59 PM
  #68
aebooth6's Avatar
I'll have a full e85 tune then a switchable pcm with 93 octane
It looks confusing but then again I'm not under the car
  #69
Devin86's Avatar
true. If you need it get it, but I don't see paying that much for stage 1 cams and staying on the stock turbo. when that k04r (I'm hoping) puts out decent numbers that will probably make more power the s1 cams on the stocker k04 and I think the prices is about the same. But if that goes well then stage 1 cams for sure with the k04r lol they can get broke in while waiting for a bigturbo/tranny set up this winter😆
Old Mar 15, 2015 | 08:05 PM
  #70
Devin86's Avatar
Yeah it did to me too but ez pz when u have your phone lol crack some bolts insert spacer take out front mount put the new 1 in. Tighten everything up. Took me like an hour took my time made sure to torque everything right and it lined up and went in smooth.Your cars behavior changes and it feels more solid taking off.
Old Mar 15, 2015 | 09:10 PM
  #71
aebooth6's Avatar
Okay thanks everyone for you input. Any last suggestions before I go ahead and buy these upgrades?
Old Mar 15, 2015 | 11:05 PM
  #72
chris88z24's Avatar
Yes. Save up for a new transmission.
Old Mar 15, 2015 | 11:22 PM
  #73
Devin86's Avatar
Rev match on Hard down shifts. Don't go wot under 3k. Get some good tires lol
Old Mar 16, 2015 | 08:57 AM
  #74
aebooth6's Avatar
I think I'm decent at rev matching and I never wot under 3k and I have brand new continental tires
Old Mar 16, 2015 | 12:12 PM
  #75
chris88z24's Avatar
You would have to do a double clutch rev match to see any benefit.
