Newbie here
Old Jan 23, 2012 | 09:03 PM
ben_gary's Avatar
any bolts on the pulley?
Old Jan 23, 2012 | 09:44 PM
Bika's Avatar
Fail Less.
Meh.
Stock you wont't harm much. Pullied/custom tuned is a different story.
I logged 14.5psi on a 34*F day once back when I had the stock pulley, and GMS1.
Maybe my peak boost rose a little higher, because I was reving to 7k?!? Who knows.
When I first got HPT, I bumped the rev limit to 7k and changed nothing else to start with, 14psi on stock pulley then. But revving to 6500 it wouldnt go past 12.5
Originally Posted by Remyred07
You know what I forgot to tell you guys I have a hole in my flex pipe could that be one of the reasons why I'm boosting at 15psi I'm taking the pick of the pullies now
No, that isn't it. A leaking flex pipe wont cause restriction that results in PSI increase.
Old Jan 24, 2012 | 07:11 AM
Staged07SS's Avatar
Administrator
Administrator
Yeah, that sounds right.
Old Jan 31, 2012 | 12:28 PM
Remyred07's Avatar
Hey sorry I'm so late but I was just told by a friend that my boost gauge is reading 2.5 when the car is off so I'm really boosting 12.5 true or false?
Old Jan 31, 2012 | 12:33 PM
Staged07SS's Avatar
Administrator
Administrator
When you just shut the car off, the boost gauge does not re-zero its self.
It usually stops somewhere in vacuum when you shut the car off.
To re-zero the gauge you need to turn your key to the on position. Check that, and see where the needle lands.
Old Feb 6, 2012 | 04:57 PM
Remyred07's Avatar
No im boosting at 15 psi idk why i know everyone is telling to to look for some things i have photos so i hope you guys can help me out
Old Feb 6, 2012 | 05:00 PM
Remyred07's Avatar
also how do i know when i need fluid in my heat exchanger and what type of fluid do i need??
Old Feb 6, 2012 | 11:35 PM
Bika's Avatar
Fail Less.
pink/orange fluid in filler neck attached to front of blower. If empty, fill with dexcool/distilled water. If fluid not moving, hit pump with hammer until flowing.
Old Feb 6, 2012 | 11:42 PM
Sox-Fan's Avatar
Got Brakes?
This still boggles my mind.
Old Feb 7, 2012 | 06:00 PM
Remyred07's Avatar
huh hit with hammer????????
Old Feb 8, 2012 | 12:40 AM
  #36
Bika's Avatar
Fail Less.
Ugh... yes, you heard me correct. hit the electric fluid pump with a hammer (not as hard as you can but firmly) to knock the dust off the motor brushes. All of our h/e pumps will fail at some point, usually before 50k miles.
brett.higgins3
Sep 24, 2015 09:51 AM
Coors
Mar 14, 2007 09:38 PM
