Newbie needing Senior help
Hey guys,I have read the faq's and found alot of great info,if you would be so kind I need some solid direction on a few mods on my 2005 Cobalt SS.
Lowering springs?Aggressive drop but not riced out.
Which torque strap or motor/trans mount will cure the thud on the 1-2 shift?
WHP capability of pump and MAF sensor?
Anyone running a dry N2O kit before the MAF?
How much WHP to expect with a 3" pulley?
Are the internals forged?
Your help is greatly appreciated and any COBALTSS.net members needing dyno time in the hillsborough,Pasco,Sarasota,Pinellas county area I'll do $75.00 an hour or 3 base line pulls for $50.00.
Thanks again
Thanks again
Thanks again
Thanks again
H&R? Sportlines look awesome, there's some pics on here somewhere.
With just a pulley and no tuning you prolly won't get a whole lot out of it. maybe 5-10 HP at the wheels.
Thanks again
Thanks again
weapon r engine dampener
hasnt been found out yet
im not sure but it wouldnt be a good idea on a returnless fuel system
270whp
yes
Don't know if anybody is interested but I just baselined my Cobalt,it did 220 whp and 190 ft.lbs. of torque.Pulled the filter aimed at the MAF with a nitrous line running through a 34 pill and it went 268 whp and 266 torque.No detonation,12 to 1 air/fuel across the board.
Good times
Good times
Originally Posted by hennessey833
you won't get 270 whp with just a 3"pulley
I thought that was a little exaggerated but didn't know for sure.I'm installing a dry kit with a 34 jet before the MAf today and I will let you guys know the result after it has been tested a little more than one dyno pass.Also I was recommended the H&R springs and I loved them in my IS300 butbthey are 2 weeks away and the eibach's are in stock at the wholesale outlet nearby.Has anyone had good results w/ the eibach's or should I just wait?
If you got a 220 baseline you should get about 235-240 with the airbox mod, plugs, and a 3" pulley.
Iceberg
Sep 29, 2015 12:33 PM
