Is this normal?
Is this normal?
This winter it seems my cobalt likes to make a metal on metal Rubbing sound when im backing up. It goes away shortly after it starts and dosent seem to happen when its moving forward. Is that normal for these cars? Ive owned 7 cars and none of them have ever done his.
Yeah, your rear calipers aren't releasing when you let the emergency brake off and now your pads are shot. I have the same issue which the dealer refused to fix. :-( Oh well, such is life.
it ur ebrake not releasing all the way.I changed my pads about 15k ago,and it is still doin it,but it only does it when i first start the car and back up.But once they warm up its all good
if it's not your e-brake, it could just be snow melting on warm brake pads, then freezing after you park it. happens to me when it snows alot. if it snow alot and its very cold i actually hear a big bang as the pads and discs break the ice between them. and that is normal.
Do you park on a hill? I have a very steep driveway that I park on, and I've had 3 Chevys ('98 Monte Carlo, '03 Monte Carlo, '06 SS/SC) and they've all done this. I've always attributed it to cold/wet weather (especially in the morning) and the brakes setting a little too tight after being parked all night.
My brakes do it once in a while when I go to the car wash and once I hit the brake it goes away. But the first time I heard it was like what the f___ . and it happens when sits all night after a good rain. I have to agree its just the slight film that builds on the rotor especially after they have been used and heated and the moisture dries and you hear the momentaty noise and vibration
Original Hayden Fanatic
Yes its normal, almost all Cobalts with 4-disk squeek when its cold out.
Mine do it when its wet too =/ usually after 2-3 stops it goes away
this is just a question out of curiosity..
i have an 07 LT coupe..and it has front discs and rear drums
is it possible for me to upgrade my front brakes to drilled/slotted rotors as well as the back? or am i screwed with forever having only front brakes
Its possible, there are a few threads about it... for daily driving its not worth the time or money to do. Unless you auto-cross/road race alot there isn't really a need for a rear conversion. Drums are more then enough in the rear for daily driving
Mine does this when my clutch is cold. Goes away once the car hits about 120*. If i let the car warm up before driving it it doesn't do it.
roth
09-26-2015 12:16 PM
