OBD2 scan tool
ill get back to you, what kind of scanner do you want? just want to know the codes? or you want a definition of the code aswell? like one can tell u the code, and u can check it online, th other shows a smll description of what tripped the code, like random misifr, or bank1 sensor 1 etc
http://www.thinkgeek.com/gadgets/car/aa31/
100 dollars...
this is just like HPtuners logger or a scan gauge, except u hook it to the computer to read the logs after you do your runs.
Keep in mind it only logs 4 perimeters at once, but that should be good if you choose the right ones.
