oil change 6 quarts and still half quart low?
Old 05-27-2006, 04:50 PM
bogout's Avatar
Just got the oil changed in my sssc. weird thing is put 6 quarts in and still a half quart low.Is it me or is it the car. Ran the car for awhile and checked it again and still the same thing half quart low?
Old 05-27-2006, 04:52 PM
Black2point4's Avatar
Thats very odd.. because I'm pritty sure the 2.0 only takes 5 quarts...
Old 05-27-2006, 05:16 PM
fastSS06's Avatar
It's always been 6 for me....and then just a lil bit more to top it off
Old 05-27-2006, 05:25 PM
Chevypowered's Avatar
it was a touch over 6 quarts on mine.
Old 05-27-2006, 05:38 PM
chevytech329's Avatar
Mine always takes 6.5 quarts especially if you let it drain for 30+ minutes
(drains all the oil out of the oil cooler)
fyi
Old 05-27-2006, 06:00 PM
discofreak's Avatar
it needs six quarts, but the oil filter will take a half a quart or so from the pan, so you end up putting in about 6 and a half quarts if you change the oil filter
Old 05-28-2006, 10:03 AM
bogout's Avatar
Ok thanks everyone. went and added a half quart.
Old 05-28-2006, 10:27 AM
DARK AGE 53's Avatar
I've read here guys say there manual says 6.5/with oil filter for the 2.0 engine, what does your manual say for the 2.0 engine?
Old 05-28-2006, 10:30 AM
bogout's Avatar
looked in mine yesterday and said 6 quarts
Old 05-28-2006, 11:00 AM
If it says 6 quarts ( for the 2.0 engine ) with an oil filter change then that's what I would put in it, why some say 6.5 I don't know.
Old 05-28-2006, 11:11 AM
Tomtwtwtw's Avatar
Be careful when topping it off...to much oil and you can mess something up. The dipstick does have a 1 quart range where it's safe to run. I haven't changed it yet, but I'm guessing from what you're all saying, it's probably 5.5-6.5, in which case 6 is just fine.
Old 05-28-2006, 11:50 AM
mqqn's Avatar
Hi bogout -
The manual says 6 quarts.
I did my first oil change and added 6 quarts and that put it in the middle of the operating range.
I wish these cars had an oil pressure and temp gage - especially since you can monitor coolant temps on the DIC.
best regards -
mqqn
Old 05-28-2006, 07:36 PM
Tomtwtwtw's Avatar
Originally Posted by mqqn
Hi bogout -
best regards -
mqqn
Exactly. And I bought my oil filter today in prep for my first change, and there's no way that thing holds a half quart...it's like the size of a kiwi.
Old 05-28-2006, 07:56 PM
cashstacker's Avatar
i put in 7
Old 05-28-2006, 09:52 PM
davytudope's Avatar
alldata.com
6.4 liters (6.75 quarts)
Old 05-29-2006, 01:13 AM
Tomtwtwtw's Avatar
Originally Posted by davytudope
alldata.com
Owner's manual - 6 quarts.
Old 05-29-2006, 10:13 AM
KillerNutz's Avatar
You act like Owners manuals have never been wrong before. Judging by the large sample size of SS/SC owners here that have to use 6.5-6.75qt of oil to fill up. I would say the owners manual is incorrect.
Old 05-29-2006, 11:25 AM
BLKSS's Avatar
Almost 7 in mine.
Old 05-29-2006, 03:07 PM
bluecobaltss06's Avatar
I've done a **** load of them at work already, I've never seen any take less than 6 and a 1/4, its usually around 6.5
Old 05-29-2006, 03:11 PM
carbombss's Avatar
7 qts here
Old 05-29-2006, 03:16 PM
Mike_42's Avatar
the crew at my dealership (when they did my first oil change for free) wrote on the top of the engine with a marker " 7 qts "
kinda bummed that they thought it was cool to write on it with a marker in a very visible spot
but it's obviously more than 6qts to properly fill the 2.0 (assuming draining fully before filling), it's a thirsty little motor
Old 05-29-2006, 03:19 PM
bluechevyss05's Avatar
there u have it anywhere from 6 1/4 to 7 depending on dranage enough said
Old 05-30-2006, 02:22 AM
Tomtwtwtw's Avatar
Well I just filled mine today, and the 6 qts I put in put me right in the middle of the operating range on the dipstick. I let it drain for almost an hour, without the filter in. I could add a half quart or so, to put it right at the very top of the dipstick, but then I'd risk causing damage to your engine by having too much oil. I'm content following the owner's manual in this case. To each his own, yes?
Old 05-30-2006, 07:14 AM
If you putting in that extra 1/2 a quart damages your engine, ill personally buy you a new one....
Old 05-30-2006, 09:43 AM
mqqn's Avatar
Hi folks -
This goes on in the corvette forums as well - People actually argue abouot how much oil needs to go into an LS1/LS6 engine.
Some people think that the dipstick HAS to be at the TOP of the operating range, whereas the truth is that anywhere in the operating range is acceptable.
If you interpret that the oil level on the dipstick has to be at the very top of the operating range, then put in the extra half quart or the whole extra quart.
You will not damage your engine with an extra .5 quart, but you CAN cause engine damage if you put in so much as to negatively affect windage and crankcase pressure.
best regards -
mqqn
Quick Reply: oil change 6 quarts and still half quart low?
