P0121
P0121
Got a check engine light. Read the code with a brother in law's scan tool. Came up as P0121 throttle body/pedal position sensor. Car has no performance issues other than I've noticed that its a bit hesitant accelerating while making a turn. The engine light was coming on for a a day or two. Then going off for a week or two. I've been using the scan tool to clear the code other wise auto start is disabled with the light on. Which doesn't serve well here in a calgary -43 winter. Gonna have a good onest mobile guy come look at it this week. But till then, has anyone else experienced this? Could it just be the throttle body needs to be cleaned? Could it just be a sensor or lose connection where the light would go off on its on after a few days?
Suggestions or theories?
I'm going through the same issue sort of lol. I replaced my throttle body but i'm still getting low throttle response and basically limp mode. I might have to replace the pedal assembly next. I also had to replace my ground wire that connects to the transmission.
BUT, I do have a spare throttle pedal in my garage (when I went through the same thing). I don't think there is a part number difference between models. Let me know if you want it. Shipping to CA might be costly, but I'm sure I'd let it go cheap enough to make it worth it.
I honestly haven't seen or heard of them going bad - it's usually the TB and/or its wiring that is the issue.
princejwp
Aug 12, 2014 07:25 PM
