passenger side leak
passenger side leak
It had been training non stop at where I live and I have noticed my passenger floor board is getting wet. There is a like coming from under the glove box does anyone one know where the water could be coming in from?
Posted from Cobaltss.net App for Android
Hope that you're able to find the source of the leak! If you would like for me to check into recall/warranty information, or if you decide to work with a dealership, please send me a private message with the last 8 digits of your VIN and contact information.
Sarah, GM Customer Service
my 2007 LS coupe is doing this same thing now, happened twice in the past week. the driver side rear floor mat is soaked, looks like it's running down from the rear corner of the door jam... and no more warranty for me and only 34k miles
Quote:
When it rains only?
When it rains only?
Why dont u try hosing it down and see where its coming from ? It might be getting in through the window
Sunroof drain line is either blocked, or your connector on the drain is loose.
Try this thread - https://www.cobaltss.net/forums/prob...unroof-282019/
it is probably the sunroof drains that are clogged. same thing happened to me a year ago. you need to pull down the head liner and clean out the tubes that lead up to the sunroof. a clog there will eventually trickle down into the lowest part of the car: the wheel wells and the spare tire well in the trunk, but that already has a drain. Good luck and hope this helps
i don't know about the OP, but i don't have a sunroof... and correction it is both rear passenger mats that are soaked, not just 1 side. i just took both door panels off and everything is absolutely dry, no moisture or water anywhere. pulled up the inner door sills and i can't see anywhere where water is running from... weird. i'm going to message a buddy that works at a local dealer and see if he knows of anything
yup theyre both fine. just did a hose test on the drivers side and my guess is that there is water running down inside the door (where i couldn't see with the door panel off) and then it must be building up somewhere until it drains out at the rear hole on the bottom of the door and then into the car. i guess tmrw ill take the door panel off again and try to make sure the drain holes are clean
yea i was just trying 1 thing at a time, since this car turned 5 last month it's been so aggravating, and to only have 34k miles hurts too
but for both windows to start leaking at the same time is like wtf? if only i had a new job i'd seriously be thinking about going back to stock and trading this thing in on something new
Sell parts for profit lol
I still think its weird that both sides are leaking....
I think I know what could have happened.... U might have put everything back together wrong and letting water in
