pedals
Old Oct 20, 2006 | 07:53 AM
xspyder85x's Avatar
pedals
i wanna get some nice pedals for my 5spd. do they come off, or is it a whole assembly. anyone replaced them yet?
Old Oct 20, 2006 | 08:23 AM
PlaysWitCars's Avatar
Former Cobalt Owner
I was looking into pedals also.....I really would like to get some black and blue ones but I also like the GM pedals.
Old Oct 20, 2006 | 10:16 AM
IMADreamer's Avatar
They are an easy fix. The clutch and brake are just pedal covers. The old ones slip off and the new ones go on. Now depending on which brand you go with it may be a different mounting method. Some use hardware, some use adhesive, and some use velcrow (stay away from that last one). I got some Tenzo R pedals from Gravana. It was an easy install. I used some adhesive to mount them temporarily while I put the hardware on. The hardware is not specifically designed for this car so I did some modifying but I don't think it's neccessary.
I believe the GM kit replaces the entire accel pedal which is not hard to do. The tenzo kit I got was just a cover so I had to modify the pedal some. It was simple. I just drilled into the stock pedal and then mounted the pedal using some hardware.
So there you go. You have several options really, all are easy to install.
Old Oct 20, 2006 | 10:44 AM
xspyder85x's Avatar
thank you dreamer, i will look into gettting some now.
Old Oct 20, 2006 | 02:39 PM
philco_3's Avatar
Proud Playstation 3 Owner
I know I did a how to on the GM Pedals. The only one that was a bitch was the gas pedal, because you had to replace the whole assembly on it.
007Buff
Jun 11, 2017 03:04 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
007Buff
Sep 22, 2015 09:48 AM
calo247
Sep 8, 2015 12:29 AM
