Performance upgrade question
I have an 06 SS/SC (G85) with a stage 2 kit, gm honed header, gmpp exhaust and an injen cai. I was wondering if I changed the spark plugs would I get more power? If so What kind do you recommend. Any other mods that I could do as well??
ok im going with the same set up but with out the gm header....so 1 step colder ngks? Also i would like the know the part number and gap
performance upgrade
I just bought a 2006 SS supercharged and i would like to do some upgrade
does anybody know anything about the stage 3 kit on the link below?
http://cobalt-addiction.com/performance.htm
any suggestion please
thanks in advance
thanks in advance
intercooler upgrade
Hi
I've a 2006 Cobalt SS S/C and I've buy a new intercooler for it
but once I've to buy a new one I want to buy a better than the stock one but the only one I got on the internet till now is from Cobalt addiction which sounds good but my problem with it is that I've to wait for about 4 to 5 weeks before I get it and I can't wait so long.
Does anybody know any other website i can get one?
thanks in advance
thanks in advance
you dont get power from plugs.
Colder plugs are better at removing heat from the cylinder, and in so doing, they reduce the risk of knock.
I would suggest 1 step colder for S2+ bolton cars personally.
I found my car ran better/smoother with them.
[QUOTE=Cobalt_SDN;1468007]you however, currently ARE from the US, unlike the other guy....you shouldnt criticize a guy for calling something the wrong name (especially when you know what he meant and realize everyone calls it this) when english isnt his first laguage
Go with ngk bkr7eix gapped at .040. I switched from the zex plugs and feel the car definitely is running better. I have stg 2, 2.8 pulley, hahn header, gmpp exhaust and cai. The car had a slight hestitation with the zex but the ngk eliminated the lag.
ECU removal for upgrading
Hi
where is the ECU of the S/C Cobalt SS located
I need some help to remove the ECU of my 2006 Cobalt SS S/C to sent it for upgrade to stage II because I don't live in the states
anybody can help ...??
thanks in advance
thanks in advance
Ditch those shitty GMPP's for some real performance parts
Here, to make things easier. Page 7 of 20, refer to the section called "Removing PCM"
http://tunersource.gmblogs.com/Racer...LSJ_Chap_2.pdf
