Performance upgrade question
Old Aug 25, 2007 | 05:39 PM
hawkeyez's Avatar
I have an 06 SS/SC (G85) with a stage 2 kit, gm honed header, gmpp exhaust and an injen cai. I was wondering if I changed the spark plugs would I get more power? If so What kind do you recommend. Any other mods that I could do as well??
Old Aug 25, 2007 | 05:41 PM
KillerBee's Avatar
Power probably not more power but what you have for mods i would go with 1 step colder NGK plugs that is what my dealershiped recommended for me
Old Aug 25, 2007 | 05:50 PM
hawkeyez's Avatar
Do you know the part number and gap size??
Old Aug 25, 2007 | 05:52 PM
JohnnySasakiMGS's Avatar
Did you install the 1 Step colder plugs? Just wondering what that mod would do for me. Sounds like you gor a pretty cool dealership!
Old Aug 28, 2007 | 09:47 PM
red06s/c's Avatar
ok im going with the same set up but with out the gm header....so 1 step colder ngks? Also i would like the know the part number and gap
Old Aug 31, 2007 | 11:14 AM
fastscion's Avatar
performance upgrade
I just bought a 2006 SS supercharged and i would like to do some upgrade
does anybody know anything about the stage 3 kit on the link below?
http://cobalt-addiction.com/performance.htm
any suggestion please
thanks in advance
Old Sep 19, 2007 | 04:43 PM
fastscion's Avatar
intercooler upgrade
Hi
I've a 2006 Cobalt SS S/C and I've buy a new intercooler for it
but once I've to buy a new one I want to buy a better than the stock one but the only one I got on the internet till now is from Cobalt addiction which sounds good but my problem with it is that I've to wait for about 4 to 5 weeks before I get it and I can't wait so long.
Does anybody know any other website i can get one?
thanks in advance
Old Sep 19, 2007 | 05:21 PM
DoubleClutchin_ION2's Avatar
lol intercooler
heat exchanger
befor modifying, please read... alot
Old Sep 19, 2007 | 05:24 PM
Woodyr007's Avatar
[QUOTE=Cobalt_SDN;1467759]lol intercooler
heat exchanger
Hey ahole he isnt even from the US, cut him some slack
Old Sep 19, 2007 | 06:29 PM
[QUOTE=Woodyr007;1467778]
Originally Posted by Cobalt_SDN
lol intercooler
heat exchanger
hey dick weed, im not originally from the US, cut me some slack...
Old Sep 19, 2007 | 06:30 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
What do "colder" spark plugs do for you?
Old Sep 19, 2007 | 06:33 PM
an0malous's Avatar
you dont get power from plugs.
Colder plugs are better at removing heat from the cylinder, and in so doing, they reduce the risk of knock.
I would suggest 1 step colder for S2+ bolton cars personally.
I found my car ran better/smoother with them.
ItalianJoe1's Avatar
Help combat detonation/knock by drawing more heat out of the combustion chamber. Becomes an issue as boost or compression gets higher or octane of the gas gets lower.
Old Sep 20, 2007 | 08:11 AM
freakta's Avatar
what are stock spark plugs on these cars?
Old Sep 20, 2007 | 06:21 PM
HunterKiller89's Avatar
[QUOTE=Cobalt_SDN;1468007]
you however, currently ARE from the US, unlike the other guy....you shouldnt criticize a guy for calling something the wrong name (especially when you know what he meant and realize everyone calls it this) when english isnt his first laguage
Old Sep 20, 2007 | 06:29 PM
telstaboy's Avatar
Go with ngk bkr7eix gapped at .040. I switched from the zex plugs and feel the car definitely is running better. I have stg 2, 2.8 pulley, hahn header, gmpp exhaust and cai. The car had a slight hestitation with the zex but the ngk eliminated the lag.
Old Feb 6, 2008 | 04:03 PM
fastscion's Avatar
ECU removal for upgrading
Hi
where is the ECU of the S/C Cobalt SS located
I need some help to remove the ECU of my 2006 Cobalt SS S/C to sent it for upgrade to stage II because I don't live in the states
anybody can help ...??
thanks in advance
Old Feb 6, 2008 | 04:08 PM
Onyxd04Redline's Avatar
Ditch those shitty GMPP's for some real performance parts
Old Feb 6, 2008 | 04:18 PM
Edubs's Avatar
Originally Posted by fastscion
Hi
thanks in advance
It's the silver thing w/ fins on it in front of your fuse box, under the hood. There are three connections you have to disconnect before you can take it out. Pull back the locks and pull the plugs out, then just pull it out by depressing the lock tabs. You'll know what I mean when you see it...
Here, to make things easier. Page 7 of 20, refer to the section called "Removing PCM"
http://tunersource.gmblogs.com/Racer...LSJ_Chap_2.pdf
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
dieGone
Oct 1, 2015 06:27 PM
