Please help a new Cobalt owner out!
Old Jan 2, 2015 | 08:32 PM
bdahlka's Avatar
Hello folks, Here we go:
2009 Chevy Cobalt LT 90,000 miles
Problems:
-Cylinder 1 misfire
-P0171 (bank 1 system to lean)
-Hesitating
-stumbling
-flashing check engine light
History:
Check engine light came on about a month ago. Throttle body was cleaned and it seemed to run good for about 3 weeks. SEL came back on and this time was running worse and flashing. Codes were read and had a long history of cylinder 1 misfire as well as P0171.
What I've tried:
-replaced all the plugs
-reset codes, they came back
-moved coil pack to cylinder II
-cleared codes (code came back cylinder 1 misfire)
-verified spark jump from coil
-swapped plugs again
-removed MAF sensor (looked brand new) didn't want to mess with it
Observations:
-disconnected cylinder 1 coil and there is no noticeable difference in rough idle
I am thinking maybe a fuel injector?
Any and all help or experience with similar issues is appreciated!
Old Jan 2, 2015 | 11:07 PM
Jesse's Avatar
Too many variables. Have you cleaned the MAF? Is your O2 sensor still any good? I wouldn't suspect the injector too badly. Clean the MAF for sure.
Old Jan 2, 2015 | 11:31 PM
kzak104's Avatar
Moms 2.4 was having similar problems. It was a fuel injector. Swap injector to cylinder 2
Also check for vacuum leaks. Mainly injector orings
Old Jan 3, 2015 | 01:20 AM
Grave's Avatar
Originally Posted by bdahlka
Observations:
I think you nailed it.
GM_Mike
Jul 4, 2016 02:43 AM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
brett.higgins3
Sep 14, 2015 01:48 PM
