removing stock grill
Old Aug 28, 2007 | 07:30 PM
chevyguy1990's Avatar
are there clips or bolts or something that you have to take out to get the grill out?
Old Aug 28, 2007 | 08:59 PM
mike25's Avatar
iuf your talking about the lower grill then there are just clips on the top and maybe the bottom of the grill that snap down over a tiny ledge...just pop em up and itl come right off...as for the top...you have to remove everything on top f the grill in the engine bay and then unscrew the grill... you will be dealing with snap pins that can be found on the underside wheel wells also....just pop em out and your ready to go....good luck
Old Aug 28, 2007 | 09:20 PM
greekss's Avatar
not to mention you may want to keep the plastic cover....so you will need to cut the plastic top grille from the cover that covers the front engine bay....i had to do it with my polished grille inserts.....some handy work with a hand saw or jig saw should do the trick tho
Old Aug 28, 2007 | 11:13 PM
ok, cool, thanks for the help guys
Old Aug 29, 2007 | 01:55 AM
HowieSS's Avatar
Check this out:https://www.cobaltss.net/forums/show...t=remove+grill
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
