Retros install problems
Old May 8, 2012 | 05:48 PM
tureka's Avatar
Broke a halo twice when installing. Will be unsealing and replacing it in June. Need to do headlight restoration as the lenses were not in good condition despite the seller on this site telling me so. Already used a restoration kit on the left light, was a buddy's leftovers not enough sandpaper to finish.
Posted from my Asus Transformer Prime
Old May 8, 2012 | 06:34 PM
breds2k's Avatar
can someone throw a pic of of the blue headlight plug properly wired? Someone showed me a pic before of how to wire it, I did that exactly now my highs/lows are backwards.
Old May 8, 2012 | 06:54 PM
tpete763's Avatar
Just flip your High/Low beam wires to fix this. Your ground wire is the center pin in the harness.
Old May 8, 2012 | 07:00 PM
Powell Race Parts's Avatar
I cant scan pictures at home here is the manual description, for 2009 'balts, its what i have here at home the rest of the books except Ion are at work.2004 Ion is totally different
this is the blue connector looking at it, clips on top
headlight high/ low/drl: center is Black , ground circuit #250 . right pin is Pink, circuit #311 right headlamp high beam supply voltage. left pin is orange, circuit #312 right headlamp low beam supply voltage.
hope this helps.
Old May 8, 2012 | 07:05 PM
tpete763's Avatar
I have a 9007 standalone harness from TRS and this is how I had to pin the harness out to get the high beams to work. I don't know If you have the same color wires as me, but I hope this helps.
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
