Reverse lights and 3rd brake light dont work
Old Nov 12, 2015 | 07:55 PM
Bthor98's Avatar
My reverse lights and 3rd brake light dont work, i even put all new lights in and they still dont work. Does anyone know why they are doing this?
Old Nov 12, 2015 | 08:00 PM
double clutch's Avatar
Does your dash lights work? They are all in the same circuit, along with the license plate light. Fuse could be blown. I believe its the park lamp one either a 10 or 15 amp.
Old Nov 12, 2015 | 08:08 PM
Bthor98's Avatar
Dash lights work, license plate light works, And my park lamp fuse isnt blown
Old Nov 13, 2015 | 11:24 AM
Then trace your wires and check your grounds and connections. You can find detailed schematics online that can help.
Old Nov 13, 2015 | 12:03 PM
umrdyldo's Avatar
Maybe the reverse switch? idk
https://www.cobaltss.net/forums/how-...ch-mu3-222552/
Old Nov 13, 2015 | 01:18 PM
Kolt's Avatar
Check for power and ground at connectors. Thatl tell you which circuit to trace.
what car do you have and ill get a connector end views for you too
Old Nov 13, 2015 | 01:25 PM
firehawk618's Avatar
A little more information as to what your car is would help a lot in troubleshooting.
I doubt the two problems you have are related.
Old Nov 13, 2015 | 03:32 PM
Bthor98's Avatar
Originally Posted by Kolt
Attachment 8526
Attachment 8527
I have a 2007 cobalt ss 2.0
Old Nov 13, 2015 | 03:58 PM
Kolt's Avatar
Reverse lights
1 is light green and should have 12v when your in reverse with key in run position
2 is black and should be ground at all times.
3rd brake light
A is light blue and should have 12v with brake pedal depressed.
B is is black and should be ground at all times
problems are not related except for at g401 and 402. they are either spliced there or multiple ground eyelets on one bolt, could be a potential place for problems but not likely. check for power first.
pykie
Jan 16, 2016 03:49 PM
68nova200
Nov 21, 2015 09:55 PM
firehawk618
Nov 11, 2015 12:52 PM
Davulao
Nov 6, 2015 12:37 PM
southal cobalt
Oct 14, 2015 06:01 PM
