a SECRET TSB I thought everyone should know about
Old Apr 4, 2008 | 09:09 AM
  #76
Edubs's Avatar
Thanks for the info fr33k.
Looks like my car falls within those dates. With the cams, I'd figure I would have already shattered the timing chain if it was a non heat-treated one. I'll keep an eye out, though. Thanks for the heads up!!!
Old Apr 4, 2008 | 10:20 AM
  #77
SS/SCking's Avatar
Thank god for a 10/05 build date here...
Old Sep 24, 2009 | 12:18 PM
  #78
Cefaln452's Avatar
now is this sortsa a recall or what?
Old Oct 2, 2009 | 08:06 PM
  #79
mrfitz's Avatar
are you guys getting a "click" when engaging a gear too? like once the flywheel and clutch meet up again?
Old Nov 4, 2009 | 02:39 PM
  #80
mrfitz's Avatar
So I posted a video of this rattle, the video is backwards but you can hear it nice and loud.
http://www.youtube.com/watch?v=8FSf0-dTFLI
Old Nov 9, 2009 | 08:47 AM
  #81
roboticfister's Avatar
Mine does this too. I also just lost 5th gear due to a bent fork because apparently the fellow that owned it before me was a fat man and drove with his weight on the shifter cruising in 5th (bad habit) and now I have the transmission out. I figured while I have the tranny out I'll go ahead and crack open the engine and fix this. Does anyone have the part number for a replacement heat treated timing tensioner? Or maybe a website or parts outlet with aftermarket options? Sure would save time trying to talk to a moron on the phone at GM trying to track the part down.
I also think I have either a bad SC bearing going out or a weak accessory belt tensioner as I also have a on again off again squeaking noise coming from the engine bay. Kind of a chirp/squeak noise that's audible about 75% of the time at all operating conditions. That'll be a little harder to pinpoint but I'll probably start with some soap on the belt and if it goes away then I'll know it's not the SC bearings.
Old Nov 16, 2009 | 02:59 AM
  #82
sealy's Avatar
that sucks...sounds like crap. my resonator and cat were messed up and sounded similar...but not quite. good luck.
Old Nov 16, 2009 | 03:02 AM
  #83
ff_drift_lol's Avatar
timing chain actuator. they changed the design. I replaced mine already. could just be that.
Old Mar 31, 2010 | 11:47 PM
  #84
Pyros777's Avatar
Originally Posted by Pyros777
Yikes. My car was built sept. 06. Hope I don't get this problem.
I think I may have this problem now. LOL
Changed the timing chain tensioner to no avail. Still have lots of rattling/ticking in the timing chain area along with the occasional stumble.
Taking it to the dealer Monday.
Old Sep 7, 2010 | 04:35 PM
  #85
doober321's Avatar
This is happening to me! ^ what happened when you took it in? I
too get the Click sound when i shft sometimes.
Old Sep 7, 2010 | 10:23 PM
  #86
Pyros777's Avatar
Turned out to be a combo of a bad belt tensioner plus an exhaust leak for me. Both make ticking/rattling noises.
Old Sep 7, 2010 | 10:49 PM
  #87
doober321's Avatar
I for sure have the same problem then. My gmpp exhaust cat is all dented to **** and most likely leaking. Do I go to the dealer to have the timing chain/tensioner replaced? Warranty?
Old Sep 7, 2010 | 10:54 PM
  #88
Frew's Avatar
jeez, first the tensioner now this
Old Sep 8, 2010 | 01:37 AM
  #89
PrincessTurbo's Avatar
How one person can destroy a brands name.
I bet that guy was fired ..
Old Sep 8, 2010 | 03:21 AM
  #90
Pyros777's Avatar
Just to clarify, your exhaust issue wouldn't cause this. They're completely separate issues. In MY case I had a whole bunch of things go wrong all at once. Just bad luck I guess. If you're concerned enough about it then by all means take it to the dealer.
DarrenGC
Dec 24, 2021 01:55 PM
biniecki
Oct 25, 2015 02:23 PM
cw383
Sep 30, 2015 12:41 AM
