Slight RPM surge - Clutch
Old Oct 3, 2009 | 01:22 AM
mrfitz's Avatar
Hey guys,
So, during normal driving, whenever I depress the clutch to shift my rpms surge by a couple HUNDRED rpm.... (small amount)
Does anyone else get this?
I also believe I have the timing chain problem as described in other threads, because I get a rattling once in a while that cant be reproduced consistently, as described here.
https://www.cobaltss.net/forums/show...hain+tensioner
I also get a "clicking sound" when gears engage. just a single click.
Does anyone think that this could all be related?
Old Oct 3, 2009 | 12:34 PM
fjordbosun's Avatar
I have an SS/SC and I see the same thing , these cars have a return-less fuel system
when you push in the clutch with your foot of the gas there is some fuel that needs to get burned off because it is not getting sent back to the tank. Just putting some revs on the engine while in neutral you may see the same thing where it takes a moment for the the
RPMs go to idle speed.
Old Oct 3, 2009 | 02:23 PM
mrfitz's Avatar
cool. thanks for the response!
bigdeertz
Nov 17, 2016 09:41 AM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
