small idea
small idea
thought i would share it with everyone.
when the air goes into your engine compartment, where does it go after? the only place it can go is down under the car.
why not modify the cowl under the back of your hood to let the air go somewhere other than under your car?
(hint, heat will exit there also)
under your stock hood there is a black plastic piece that goes along the bottom of the windshield, there are ways to modify it to make the entire structure act like a heat extractor
I know what your talking about. The solution is not a new one look here for the honda/import boys solution.....
A cowl induction hood works because there is a high pressure at the base of the windshield and it forces air down into the engine bay, so is this going to let air out from under the hood, or shove air into engine bay?
its just an idea i was throwing out to see where it went. ive got plenty of custom one off stuff done to my car im just letting someone else in on an idea, just sharing a bit, alot of people do it, just something to think about but apparently no one hear likes ideas hahahaha
I don't think ducting heat down would be as easy as ducting heat up since it rises naturally.. hence the whole hood vent craze.
I do know though that some vehicles are designed for specific hood/underhood configurations. These encourage proper airflow through the intercooler, radiator, and engine bay in general which helps cool things down. Aircraft are the same way. If you take the cowl off an airplane or change the plastic/rubber ducting and idle it, it may overheat. You just don't get the airflow into/through the places where you need it.
The plastic piece that sticks down under your car's front bumper is a similar device. I've actually heard of people's engines getting hotter when these pieces are broken off/missing.
