small idea
Old Mar 14, 2009 | 12:38 PM
freakta's Avatar
small idea
thought i would share it with everyone.
when the air goes into your engine compartment, where does it go after? the only place it can go is down under the car.
why not modify the cowl under the back of your hood to let the air go somewhere other than under your car?
(hint, heat will exit there also)
Old Mar 16, 2009 | 01:12 PM
freakta's Avatar
45 people look no one says anything, no one has an opinion or anything constructive to say hahahaha
Old Mar 16, 2009 | 01:13 PM
roadrage06's Avatar
yeeeeeeaaaaaaaah, i got nothin'
Old Mar 16, 2009 | 01:15 PM
DBewley925's Avatar
Why you get a heat extracting hood...
Old Mar 16, 2009 | 01:25 PM
freakta's Avatar
this is like making a heat extractor without changing the outside of the car. just a diff way of doing things
Old Mar 16, 2009 | 01:28 PM
HunterKiller89's Avatar
im cnfused. it sounds like your talking about a cowl induction hood or a heat extracting hood.
Old Mar 16, 2009 | 01:31 PM
freakta's Avatar
under your stock hood there is a black plastic piece that goes along the bottom of the windshield, there are ways to modify it to make the entire structure act like a heat extractor
Old Mar 16, 2009 | 02:07 PM
DBewley925's Avatar
......... This thread is fail........ If you want air to leave other than under the car buy a cowl induction, heat extractor, Or other type of hood... will fix your problem...
Old Mar 16, 2009 | 02:21 PM
LethalSS's Avatar
drive wit the hood off?
perhaps?
Old Mar 16, 2009 | 02:50 PM
roadrage06's Avatar
well, too many posts in here. Time to give us the answer.
if you take the whole thing off you risk getting rain down there, so I know that's not it.
Old Mar 16, 2009 | 02:59 PM
SS/SCking's Avatar
I know what your talking about. The solution is not a new one look here for the honda/import boys solution.....
Old Mar 16, 2009 | 03:02 PM
roadrage06's Avatar
if that's what it is.....i'll pass. not worth a couple degrees to look like you were in an accident or your hood is broke.
Old Mar 16, 2009 | 03:11 PM
SS/SCking's Avatar
lol thats why the import boys do it and not us....
Old Mar 16, 2009 | 04:00 PM
383_Stroker's Avatar
A cowl induction hood works because there is a high pressure at the base of the windshield and it forces air down into the engine bay, so is this going to let air out from under the hood, or shove air into engine bay?
Old Mar 16, 2009 | 06:31 PM
DarkSergeant's Avatar
I've heard of big boost Solstice and Sky's modifying the piece of trim that runs along the bottom of the windshield for this purpose.
Old Mar 16, 2009 | 06:34 PM
WhiteSSBalt's Avatar
Not a Sebring
x2. I'll keep a little bit of extra heat in over having my hood aligned all funky like.
Old Mar 17, 2009 | 12:31 AM
freakta's Avatar
its just an idea i was throwing out to see where it went. ive got plenty of custom one off stuff done to my car im just letting someone else in on an idea, just sharing a bit, alot of people do it, just something to think about but apparently no one hear likes ideas hahahaha
Old Mar 17, 2009 | 07:37 AM
roadrage06's Avatar
no the info was appreciated, like you said, it's nice to throw it out there and source everyone's brain. there might be an aerodynamics genius in the house present that can enlighten us on how the airflow over and into the engine by would work..... you never know.
Old Mar 17, 2009 | 03:41 PM
freakta's Avatar
thats all im trying to do but it seems like more trouble than its worth hahaha o well
Old Mar 17, 2009 | 04:26 PM
Stamina's Avatar
I don't think ducting heat down would be as easy as ducting heat up since it rises naturally.. hence the whole hood vent craze.
I do know though that some vehicles are designed for specific hood/underhood configurations. These encourage proper airflow through the intercooler, radiator, and engine bay in general which helps cool things down. Aircraft are the same way. If you take the cowl off an airplane or change the plastic/rubber ducting and idle it, it may overheat. You just don't get the airflow into/through the places where you need it.
The plastic piece that sticks down under your car's front bumper is a similar device. I've actually heard of people's engines getting hotter when these pieces are broken off/missing.
Old Mar 17, 2009 | 11:25 PM
do you know how fast heat rises in the atmosphere? not very fast. maybe a couple miles an hour. Do you know how fast the air is flowing into the engine bay? well, how fast is the car moving? At almost any speed, the fact that heat naturally rises is a non-issue when dealing with aerodynamics. HOWEVER, i do still agree that it would be better to make the air go over the car instead of under it.
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 20, 2015 09:56 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
MrInsanityWolf
Sep 29, 2015 04:54 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
