Sound Sytem Crashed! Please Help!!!!!!!!
Old Aug 5, 2007 | 12:56 PM
My06Kobalt's Avatar
Question Sound Sytem Crashed! Please Help!!!!!!!!
well, no help from the audio/video section. hoping you guys can shed some light over here. okay.... i got 4 Infinity 12" subs running from 2 amps. An infinity and a power acoustik. My infinity amp just shut down for no reason. no power led or protect led is on. My other amp works fine still. They share the same ground and remote wire. My power, ground and remote are all wired fine, but still no power to the Infninty amp. all connections are solid. all external fuses on the amp and power cord are fine. my RCA signal is good, too. are there internal fuses i could've blown or anything else i missed?????
Old Aug 5, 2007 | 01:08 PM
KlutchSS's Avatar
things break,and im sure this is what happened. just get a new amp.
Old Aug 5, 2007 | 01:13 PM
Halfcent's Avatar
I'm old school
If it did work once, and now it doesn't, and nothing else changed, then it's broke. No better explaination is available. Pull it and get it fixed or replaced.
Old Aug 5, 2007 | 01:14 PM
My06Kobalt's Avatar
Not really. Its almost new, but not under warranty anymore. Its their most expensive amp. I'm not just gonna go buy a new one. I'm sure its something stupid that can be fixed. I just wanted to see if anyone has any ideas of what could be wrong. Last resort is to pull it and crack it open to test it. I just want to make sure I didnt look over anything.
Old Aug 5, 2007 | 02:42 PM
andresfurueta's Avatar
the same thing happened to me, i checked all the fuses and everything seemed fine, i was getting power from all sources but no sound, recheck the fuse that goes from your battery to your amp, its probably blown but looks ok, i put in a 250 amp circuit breaker and never had this problem again, AND I HOPE TO GOD THAT YOU ARE USING A CAP!!!
turbochargedss2012
Sep 20, 2023 12:17 PM
bigdeertz
Nov 17, 2016 09:41 AM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
