Speedometer question
Old Feb 12, 2013 | 02:08 PM
mikeman428's Avatar
I was just wondering if the speedometer was calibrated by the size of the front or rear wheels.
Old Feb 12, 2013 | 02:15 PM
CannonBalt's Avatar
Drive wheels
Old Feb 12, 2013 | 02:17 PM
damastah's Avatar
front ofcourse...
also our speedometer has major lag.
Old Feb 13, 2013 | 03:44 PM
FenderGuitars777's Avatar
Front because front wheel drive.
Old Feb 13, 2013 | 03:53 PM
i thought it was rear because when my tires spin the speedo doesn't climb
and what he's asking is if the SIZE of the wheels can change the speedo. idk on that one i think so though
Old Feb 13, 2013 | 08:06 PM
damastah's Avatar
yes. size WILL change the speed. you have to get it re-calibrated if you get bigger wheels. or smaller. lol..
or even higher or lower aspect ratio on the same wheel, you would need to re-calibrate it
Old Feb 13, 2013 | 08:19 PM
Cobalt_Daddy's Avatar
your speedo runs off a sensor on your transmission IIRC. so if you spin your speedo climbs.. change the tire size and the distance you cover with each RPM will change. it's drive wheel dependant since they are the only ones directly connected to your transmission.
Old Feb 14, 2013 | 01:09 AM
insylem's Avatar
lsd?
Old Feb 17, 2013 | 01:42 AM
black07cobalt's Avatar
I put 205-65-15s on and when it shuts off at 115 GPS says 124
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
