Spring build 2018!
Old Feb 13, 2018 | 08:32 PM
TurboTechRacing's Avatar
Spring build 2018!
Let’s see everyone’s progress and status of their new builds. (Call it: “New for 2018”)
Old Feb 13, 2018 | 10:38 PM
ProfDNS's Avatar
Still stock with only a lonely injen intake
Old Feb 13, 2018 | 10:56 PM
Still looking for the appropriate shell
Old Feb 14, 2018 | 07:35 AM
Lots of plans but no money or ambition for the poor cobalt right now...
Old Feb 14, 2018 | 08:51 AM
jdbaugh1's Avatar
Just getting ready to finish up installing new lightweight flywheel, fender-well liner,clutch, axles, Koni front adjustable strut inserts, more aggressive hawk brake pads, and a Quaife LSD in my F23 trans. Now I just need to order some tires and I will be ready for the 2018 autocross season.
Old Feb 14, 2018 | 08:54 AM
Tdubbs's Avatar
Got my warrantied Z54 back from ZZP, and ordered everything to redo the timing set. Just need to buy a bunch of gaskets, then find time to do it all. I still need to pull everything after the turbo to clean it from when it blew.
Not exactly a "build", so we'll call it Spring maintenance.
Old Feb 14, 2018 | 09:03 AM
Hopefully find time to install the f40 and meth kit on the car
Old Feb 14, 2018 | 10:36 AM
63 Nova SS's Avatar
Hopefully find time to get the undercar rails from omiotek and get them installed along with the 6758 that's been setting in the garage for a year. At least it's still driveable.
Old Feb 14, 2018 | 12:56 PM
royce777's Avatar
sell it
Old Feb 14, 2018 | 02:28 PM
63 Nova SS's Avatar
Originally Posted by royce777
sell it
I'm honestly thinking about not installing the turbo at this point and waiting a couple years to by an awd ats, and installing it on that instead. Might save the motor if I do.
Old Feb 14, 2018 | 05:45 PM
Henry3959's Avatar
I should be done by Spring but our weather will still be crap.
Old Feb 15, 2018 | 09:16 AM
royce777's Avatar
more than likely going to end up with a ATS
Old Feb 15, 2018 | 09:57 AM
cw383's Avatar
I'm doing the 15" wheel conversion on the front so I can run some M&H slicks. I know 17's fit and I can keep the Brembo's but theres quite a few benefits on the 15's, so thats what I'm doing. All in all losing about 34lbs of weight on front wheel/tire setup, plus I'm sure the brake/rotors might lose a bit.. Also throwing in a new clutch and using an ACT steel flywheel. People either love or hate the lightweight flywheels, but my thoughts are its going to be a lot easier on the car banging gears, less shock to the trans, so it's an acceptable compromise. Also doing some new F5 struts ( I threw some piece of crap Monroe's on when I was trying to track a front end noise ). I'm thinking of using some YYZ springs. I asked Powell how they would work in a drag setup, he thinks the rebound rate may be a benefit.
Old Feb 15, 2018 | 10:04 AM
jdbaugh1's Avatar
I'm personally a big fan of the YYZ springs ^^^
Old Feb 15, 2018 | 10:30 AM
cw383's Avatar
Have you raced with them? I have huge front end rise. I've experimented with various poundage in my rear air bags, I ended up using next to no pressure, it was the lesser of 2 evils to have squat VS nose so high in the air. I'm thinking it could have been my struts/springs. I may also try front end limiting straps like cmiller used to use
Old Feb 15, 2018 | 10:49 AM
jdbaugh1's Avatar
I honestly can't give you much feedback as far as drag racing as I am sure your setup and tires are much different than mine. I have drag raced once but that is even close to enough experience to offer advice. I primarily use mine for autocross and think they are awesome for that.
Old Feb 15, 2018 | 11:05 AM
07blackg5's Avatar
Slobodan Milošević
New longblock going in. Dropping the bottom end stuff off at the machine shop for balance/fit/assembly on saturday
Old Feb 15, 2018 | 12:29 PM
Jesse's Avatar
ricer
Old Feb 15, 2018 | 12:36 PM
Originally Posted by Jesse
ricer
Yup, fake news
Old Feb 15, 2018 | 01:02 PM
royce777's Avatar
have you tried sway bar bushings?
Old Feb 15, 2018 | 01:16 PM
07blackg5's Avatar
Slobodan Milošević
ricer
Yup, fake news
Old Feb 15, 2018 | 02:40 PM
cw383's Avatar
Yes did. It wound up being a defective CAB that I couldnt see.
Old Feb 15, 2018 | 02:44 PM
royce777's Avatar
which CABs are you running?
Old Feb 15, 2018 | 02:56 PM
cw383's Avatar
It might not need any balancing at all. When I dropped mine off, I was having them mic all the bearing surfaces for blueprinting and having it balanced. When I went to pick it up they said they didn't balance it, it didn't need it. I was immediately skeptical and major bummed, was going to take it elsewhere. Then I did some reading. On a 4cyl, each throw has a piston/rod 180 degrees out that counteracts the opposite side. And the crank is zero balanced from the factory. That being the case, aftermarket pistons usually come matched within a few grams of each other right out of the box. Rods are the same way. So you might be perfect without even touching it.
Old Feb 15, 2018 | 03:25 PM
cw383's Avatar
Powells now. It was a Moog spherical when it went bad before
