SRS AirBag Light Solution?
Old Sep 23, 2022 | 04:40 PM
Cxre_l3ss's Avatar
Talking SRS AirBag Light Solution?
2010 lnf ss, airbag light comes on sometimes fix????????
Old Sep 23, 2022 | 04:49 PM
cobaltss#01's Avatar
How's your battery? If it's low it could cause it.
Old Sep 23, 2022 | 06:32 PM
Pull the codes. Body module codes should provide an indication of what is causing the light.
It could also be the wiring to the yaw sensor or the yaw sensor itself under the passenger seat.
Old Sep 24, 2022 | 09:41 AM
Kolt's Avatar
Def get someone to pull the codes. Including the byte symptom. ^both of those issues can cause intermittent airbag light but also a very common problem is the passenger front seatbelt. It has a tension sensor at the floor for detecting how big of a child/person is in the seat. Factory wire routing was poor and they made a update to fix it but I still see the old routing alot at work causing breaks inside the small harness. I fixed my ls years ago and I've been lazy to fix my ss one of these days
Old Dec 9, 2022 | 04:58 PM
mitche35's Avatar
As Kolt just said the wiring on pass seat belt has problems, there is a tsb on it, you have to pull up a little carpet, cut some of the plastic and give wires some slack. Also the bladder? or whatever it is that knows when some one is sitting on pass seat has problems, it's in the seat bottom. When my light goes on, I shut off car, punch the pass seating surface, push it up from underneath and also push the red buckle release for pass side, start car again and it's usually off. check that the pass seat electrical connection is fully connected also.
YamaRoostin78
May 3, 2014 04:46 PM
derekhollister
May 31, 2013 06:29 AM
sternerG85SC
Oct 29, 2010 03:32 PM
jaygo7007
May 14, 2009 11:12 AM
r0me ag3nt
May 2, 2007 01:49 PM
