SRS AirBag Light Solution?
Pull the codes. Body module codes should provide an indication of what is causing the light.
It could also be the wiring to the yaw sensor or the yaw sensor itself under the passenger seat.
Def get someone to pull the codes. Including the byte symptom. ^both of those issues can cause intermittent airbag light but also a very common problem is the passenger front seatbelt. It has a tension sensor at the floor for detecting how big of a child/person is in the seat. Factory wire routing was poor and they made a update to fix it but I still see the old routing alot at work causing breaks inside the small harness. I fixed my ls years ago and I've been lazy to fix my ss one of these days
As Kolt just said the wiring on pass seat belt has problems, there is a tsb on it, you have to pull up a little carpet, cut some of the plastic and give wires some slack. Also the bladder? or whatever it is that knows when some one is sitting on pass seat has problems, it's in the seat bottom. When my light goes on, I shut off car, punch the pass seating surface, push it up from underneath and also push the red buckle release for pass side, start car again and it's usually off. check that the pass seat electrical connection is fully connected also.
