SS Exhaust diameter ???
Old Apr 8, 2008 | 03:42 PM
PsychoCam's Avatar
I have the ss exhaust on my car and I am cutting off the muffler and adding another high flow muffler. what is the Inside diamter of the piping right before the muffler and what is the Outside Diameter
P.S I know the exhaust is 2.5" then right before the axle it goes to 2.25"
Old Apr 8, 2008 | 03:47 PM
Cobalt30's Avatar
If your cutting it off then why dont you check after you cut it?
Example 4: The circumference of a circle is 15.7 centimeters. What is the diameter? [IMAGE]
Solution: C equals Pi times d
15.7 cm = 3.14 ˇ d
15.7 cm ÷ 3.14 = d
d = 15.7 cm ÷ 3.14
d = 5 cm
Now you can think outside the box. go outside and measure the piping around to get the circumference and then use this sweet formula/ example to figure it out
Old Apr 8, 2008 | 03:51 PM
RollOver360's Avatar
2 1/4 OD I think. So that means if u want to put a muffler on directly to the stock piping, the muffler inlet would have to be 2 1/4 ID to fit.
later
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
