stage 2
you need to be a bit more specific. did you buy a stage 2 kit? or just a pulley? if you got the kit then it came with injectors so you are already set. if you just got a pulley then it depends on what size pulley, if its just a stage 2 pulley then the 42 pounders are fine, although if you just got a pulley you will need a tune and if you have access to a tuner you might as well go ahead and get 60# injectors so that you wont have to worry about fuel needs if you upgrade more.
