What does everyone think of this turbo manifold?
This turbo manifold is from vulcan turbos, here are the specs:
Tube Material: 304L Stainless Steel
Flange Material: 1018 Cold Rolled Steel
Flange Thickness: 0.500" (12.7mm)
Tube Thickness: 0.109" (2.77mm)
Flange Thread: 10x1.5mm RH
Weld Procedure: GTAW (TIG) 308L Filler
Manifold Height: 3.82" (97mm) Flange face to face
Manifold Volume: XXX Cu.In. (XXX Cu.CM)
Standard Turbo Flange: T3 Style Threaded
Available Flanges: T2, T3, T4, TD05 DSM
Flange Offset: Perfect Center 0.00" Offset
Options: 35/38mm wastegate flange +$33.00
Part # 7-13-2202D
Price: $325.00USD
What does everyone think of this manifold? Its a little pricy but it seems like it would be hella nice to have. and also can i still angle the blower upwards and route the piping up and around the engine since the flange is angled downwards?
log manifolds are not the best efficiency wise, other than that it looks like a quality made piece. your best bet would be a tubular manifold, which would probably have to be custom made.
