stalling of the motor????
Have a Auto, 2.2. Cobalt and the other day I was Drifting and seeing what i can do basicly in a BIG parking lot and the wheels would spend and then its like the motor shuts off and when it gets back to a Certain RPM it comes back to life..... it does this also if u have it in Nut. and give some gas and put in DRIVE Gear.... SHUTS OFF THEN kicks back on.... it like a 3 sec delay????
Im going to guess its a saftey feature that seems to be annoying in your case. The reason i guess this is i tryed to do a reverse 180 in a cavalier i had that was an auto a year or so ago and the motor just cut off on me when i went to drive.
Since its an automatic, chances are its the traction control kicking in.
My Cavalier has the same thing, basically when you get the wheels spinning, the T/C comes on and cuts the power. It does it by retarding the engine timing, cutting the throttle, and upshifting the trans to a higher gear.
So when it feel like its bogging down, thats the traction control coming on and spoiling your fun
You should be able to disable it by locking the shifter down into 1st or 2nd gear - an indicator on the dash should come on saying something like "trac off", which means the system is turned off completely and won't intervine.
Originally Posted by stlurbanpunk
yeah there are some tricks to get around it. In my car, (98 cavy) I just click the e brake up one click. in newer cavaliers i dont think this works, makes a dinging noise, you know the "your e brake is on you idiot" noise. i have no idea with the cobalts.
Yeah I could do that in my 97 Cav.
I'm not sure about the Cobalt either, I think he should just try it with 1 click and see what happens.
Originally Posted by Florida 76
you cant drift in a FWD car
____________
____________
Hum?? where do u get ur info from man, you dont need RWD to do drifts, its a nifty invention called the E-brake (or handbrake or parking brake) or w/e u want to call it.
U can drift any car even FWD i know ive done it, kinda fun to!
I've done it so much on my car that the cable stretched out and needs to be re-adjusted!
I like to drift in the rain and snow, saves the tires.
yeah, just make sure u COMPLETLY lock the rear wheels, or ur brakes will suffer.
You cant take most NEWER auto's from reverse to Drive or neutral to drive with any throttle...
this is so all of the smarty pants out there dont blow their trans.....
as for the motor shutting off.... I dont think it shuts off ... most likely it cuts power until ti feels it is safe from your madness again...
Now I know why they made it hard for people to shift from reverse into drive and do a neutral drop... people like you who ruin their car....
ThoR294
Oct 4, 2015 08:44 PM
