stereo
Old Mar 27, 2015 | 01:06 PM
cobalt488ss's Avatar
stereo
so this is my first post on this forum and I would just like to know about hooking up an aftermarket stereo deck in my 2005 cobalt ss/sc. I know that I have to run a wire from the fuse panel for power and was just wondering what fuse people are hooking this wire up to for it to work. thanks in advance!
Old Mar 27, 2015 | 06:24 PM
Superbolt's Avatar
You shouldn't have to run any wire ..get the plug and play harness
Old Mar 27, 2015 | 06:38 PM
Is that with the module for the steering wheel controls because I'm doing it without that and I've talked to a couple people and they said I need to wire it from a fuse that turns in when the key is turned on for the deck to turn on
Old Mar 27, 2015 | 07:16 PM
Superbolt's Avatar
Oh ya well I wish the people you talked to helped me lol . I have been trying to find out why my was wired like that for days. Someone said there's a fuse blown that why it had a wire for key power. But anyways that being said I have a wire for my key power too. I used the little green wire in the fuse area down bye the passenger foot well on the left side. Put a fuse on it too don't run it straight. It turns on with the key and stays on after the key is turned off until the timer counts down then shuts off. I had to change the way the previous owner had it done they had it going to the fuse box under the hood. It's alot cleaner looking when there isn't wires going into your fuse box. And plus you don't have to run a wire threw the fire wall.
Old Mar 27, 2015 | 07:21 PM
Okay thank you so you ran it to a fuse spot that isn't being used by something then put a fuse in it for the stereo?
Old Mar 27, 2015 | 07:26 PM
Superbolt's Avatar
Nope..remove that cover and you will see a bunch of wires and fuses I used the little green wire to the left spliced it with a butt connector and put a fuse on the wire going to the deck.
Old Mar 27, 2015 | 07:29 PM
Superbolt's Avatar
You know where the second fuse box is right ?
Old Mar 27, 2015 | 07:33 PM
Yeah I know where it is passenger side at the bottom
Old Mar 27, 2015 | 07:38 PM
Superbolt's Avatar
Just under the deck yup.
Old Mar 27, 2015 | 07:40 PM
Superbolt's Avatar
You all good now ?
Old Mar 27, 2015 | 08:30 PM
Yeah I think I got er thanks alot
Old Mar 27, 2015 | 08:44 PM
Superbolt's Avatar
No prob man.
Turbo6
Sep 30, 2015 09:14 AM
Turbo6
Sep 24, 2015 04:15 PM
soundjunky
Aug 28, 2015 03:24 PM
Turbo6
Aug 27, 2015 08:37 PM
stealththx
Sep 3, 2005 03:00 AM
