Stupid Dyno Max VT
Old Jul 27, 2011 | 05:12 PM
ezekielguy86's Avatar
Stupid Dyno Max VT
Ok I put this Dyno Max VT muffler on my SS/SC in feb since my magnaflow that came on the car was way too loud. Well I loved the sound of the VT untill about month or two ago when the little flap inside the muffler started making noise. It sounds like junk to be honest. I just wanted to know if anyone else has tried this muffler and had the same issue and if you found a way to fix it.
I would also like to note that the muffler is not a quite as it used to be but its still way better than what I had.
Old Jul 27, 2011 | 05:37 PM
Yea I've looked around I now see the bad news everyone talks about. I just want a solution. I see everyone recommend the dynomax super turbo but I really think it would sound fine if I would figure a way to rip the flap out.
Old Jul 27, 2011 | 05:39 PM
Omnigear's Avatar
warranty =p
Old Jul 27, 2011 | 05:40 PM
Hockeyman's Avatar
mufflers wear out over time especially on cobalts, take it to your local exhaust shop and see if they can yank the flap out. I'm currently running the dynomax superturbo and I've had a piece if it break off on the inside and get lodged near the tip, probably not buying that brand again.
Old Jul 27, 2011 | 05:41 PM
100% METH's Avatar
same issue
on cold days or 1st gear roll outs i can hear the flap rattling
Old Jul 29, 2011 | 02:12 PM
Ok so they are going to replace the muffler under warrenty and they advised me to move from part number 17156 to 17956 same muffler just stronger spring. Now should I do this or get a super turbo muffler. If so what part number do you recommend?
Old Jul 29, 2011 | 02:16 PM
hawlyns711's Avatar
I bought the super turbo just the other day, waiting to install maybe this weekend. hopefully mine doesn't **** the bed. if you bought one and it broke, I would advise against buying that same one again. that should be obvious.
Old Jul 29, 2011 | 04:04 PM
what model number did you get?
Old Jul 29, 2011 | 05:31 PM
any body down with sharing your part numbers that you have had good luck with. I want quite will a little tone.
Old Jul 30, 2011 | 09:21 AM
Old Jul 30, 2011 | 09:24 AM
hawlyns711's Avatar
mine was 17748 - Super Turbo; Muffler
install today
Old Jul 30, 2011 | 11:29 AM
Dieselracer's Avatar
Anyone know where i can find a good sound clip of the super Turbo, or the VT? can't seem to find one. How much louder over stock is it? I am thinking about doing catless full 3 inch, exhaust, but i don't want it very loud. maybe just a bit more and a little deeper then stock.
Old Jul 30, 2011 | 11:44 AM
nizzle's Avatar
The spring that controls the flap wears out over time. Nothing you can do about it. I went from stock to magnaflow to VT series then to super turbo. The super turbo is the best one yet imo.
I've found that sound clips of exhaust dont do them any justice.
Old Jul 30, 2011 | 11:50 AM
How much louder is the Vt at WOT over the Super Turbo? And how about at part throttle? What about the sound, any rasp etc? I think i may go super Turbo, but not sure if i need the extra flow of the VT. Since i will be racing mine.
Old Jul 30, 2011 | 12:12 PM
nizzle's Avatar
The super turbo is much quieter and helps with rasp. The VT series is a straight thru design with a flap attached to a spring. So when the flap is closed or mostly closed it helps keep the noise down, but when the flap is all the way open it's just as loud as a magnaflow. As far as flow is concerned, I have the super turbo on my car and my last dyno was 312 whp.
Old Jul 30, 2011 | 02:33 PM
Erick161's Avatar
kinda glad I unloaded mine before I installed it. I'd just stick with the super Turbo
Old Jul 30, 2011 | 03:02 PM
my local advance auto has a 17733 think about getting it.
Old Jul 30, 2011 | 07:24 PM
Look like the difference between the two is not much. the super turbo is 700scfm and the VT is 841.
Old Aug 1, 2011 | 04:35 PM
hawlyns711's Avatar
I just installed my super turbo with a full 2.5" and it sounds great. just a bit louder than stock, I'm catless also.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
