Suggestions on Storage
Old Dec 10, 2006 | 04:45 PM
06Pursuit's Avatar
Canada Suggestions on Storage
im going to be storeing my car over the winter, for about 4 months. Do you guys have any suggestions on some preperations i should do for the car? Is it better to have it on blocks? thx again for the imput. BTW I don't have a garage so the car is going to be outside, i have a cover for it but im need some more input
Old Dec 10, 2006 | 04:48 PM
CTORANGESC's Avatar
First off if you dont plan on touching it all all for 4 months, you should deff. put it on blocks or jackstands, if you don't you will have flat spots on your tires.
Old Dec 10, 2006 | 04:51 PM
06Pursuit's Avatar
well i ususaly when we get a break in the weather, i take the car to the car wash to get it cleaned, for the last 2 weeks its been uncovered so i figured Id wash it today, but that lead to driving it around lol oops
Old Dec 10, 2006 | 04:56 PM
CTORANGESC's Avatar
If you plan on cleaning it and driving it, then all I would suggest id the cover, thats really all you need.
Old Dec 10, 2006 | 04:58 PM
06Pursuit's Avatar
alright thx ctornagesc
Old Dec 11, 2006 | 02:34 AM
Grimsaviour's Avatar
Here's what you should do:
1. Warm up your car on the big day fully and then go to your local store where you buy parts and buy something like Marvel Mystery oil. Pour the whole thing into the gas tank this will preserve your fuel and also lubricate your engine.
2. Change your oil and filter
3. Drain and flush your cooling system and refill with 50/50 antifreeze/water make sure to use GM dex-cool.
4. Top up your trans, steering, brake, clutch fluids.
5. Wax your car and clean the inside well.
6. Lay down a big plastic where you will be parking your car to act as a moisture sheild to help against rust. Drive onto it.
7. Jack up your car and put it on either jackstand or the less damaging wood blocks so your suspension is loaded, make sure that it is sitting straight on blocks so the weight is disributed evenly as if you where on level ground. If your suspension isnt loaded your shocks and springs can get kinda stuck unloaded, not good.
8. Remove your battery and store in a dry place. If you have a low trickle charger its a good idea to run it on there about once a month or so or at least put it in your car and run it once a week so it doesnt die for about 30 mins.
9.put a bag over your exhaust and air cleaner intake tip or conical air filter to keep moisture and bugs out. snap em tight with a rope or elastic.
10. throw some moth ***** in the trunk and your floor to keep critters out. Leave one window open a crack so your car can breathe.
11. make sure your tires are completely covered so the sun doesnt get to them or better yet remove em and store em in a cool dry place same with your battery. Make sure your battery is off cement or the ground. put it on a 2/4 or on a wood bench.
12. cover it up and once a month turn the axles manually to lube up the gears in your tranny and such, its not a bad idea to do the same with manually cranking the engine, or start the car once a week.
So yea thats what i know, i also did some research for some of the stuff. enjoy!
Old Dec 11, 2006 | 09:23 AM
mkulrey13's Avatar
mines going to be in my garage till april and all im doing is having my brother start it up once a week and have it run till collent is around 180ish, then shut down.
mkulrey13's Avatar
of course it has a cover as well.
Old Dec 11, 2006 | 03:54 PM
Ramps's Avatar
You don't need to go nuts. I stored my old car and all i did was make sure it was clean and waxed, and had fresh oil in it. I unhooked the battery and left it for 4 or 5 months. I would go out to where is was stored every 3 or 4 weeks and hook the battery up, start it and let it warm up, roll it forward and backward (it was in a warehouse with a bunch of cars so i had a bit of space) and then i would shut it off and unhook the battery again. No blocks needed, and gas takes longer than 4 months to gell so don't worry about it.
It always started perfect, battery never died. Nothing ever seized. Then change the oil again in the spring when you bring it out.
Old Dec 12, 2006 | 12:22 AM
06Pursuit's Avatar
thx alot guys, uve been a huge help
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
TedSS
26
Oct 10, 2015 04:30 PM
yellow dragon
Sep 28, 2015 09:49 PM
Hill1513
Sep 21, 2015 07:18 AM
