torque dampener
Old Dec 25, 2007 | 03:42 PM
Inferno's Avatar
torque dampener
is there any real differnce between the weapon r and the ingalls stiffy torgue dampener?.
Old Dec 25, 2007 | 03:45 PM
Raven SS's Avatar
if ur buying one brand new i recommend just buying a engine mount...there has been cases to where people have cracked there tranny casing unless u have tranny prothanes...IMO...i dont know much between the 2 but that everyone on here that has one usually has the ingalls
Old Dec 25, 2007 | 03:48 PM
Inferno's Avatar
thanks for the advice. is it that hard to install the solid motor mounts, i mean a drivewayjob or a shop job?.
Old Dec 25, 2007 | 03:53 PM
cobalt_driver's Avatar
um depends. if u know what ur doing, about 1-2 hrs at the most for 2 engine mounts and tranny mounts. u need a jack, jackstands and probably a 3/8ths drive set if i had to guess. maybe a 1/2in. shouldn't take that long. the biggest bitch about it is lining the engine back up with the mount. ummm 2-3 guys shouldn't take too long. i would suggest a garage though, not a drive way. my buddy n me did his mounts on the good ole' srt. took us about 1 1/2 hrs.
Old Dec 25, 2007 | 03:59 PM
Raven SS's Avatar
where did u get the second engine mount? engine mount took longer to read the directions than to do lol..just jack the engine up a little bit but make sure u have a wood block on the jack...unbolt it..replace...bolt down...release the jack and check the tightness again then ur off...tranny mounts are not hard to install but taking out the stock bushings is a bitch
Old Dec 25, 2007 | 04:06 PM
ya we did the engine mount n the 2 tranny mounts with i forgot what it was...not polyurethane but it was the next strongest material. but we replaced the 2 engine mounts n then did the 2 bushings for the tranny.
Old Dec 25, 2007 | 05:12 PM
Raven SS's Avatar
oh so u filled urs...i bought mine from ttr
Old Dec 25, 2007 | 05:18 PM
95cam86roc's Avatar
The ones w/the tranny mounts, how do they hold up over time? And are the worth the money? I already have a TD and have been considering them.
Old Dec 25, 2007 | 05:21 PM
KillerBee's Avatar
TTR one of the top vendors on this site
Old Dec 25, 2007 | 05:37 PM
Raven SS's Avatar
ive heard that the tranny mounts are too stiff..just get the prothanes for ur stock mounts
Old Dec 25, 2007 | 05:44 PM
95cam86roc's Avatar
Raven- Are you talking about the mounts from TTR? Those are the ones that i was looking at.
Old Dec 25, 2007 | 05:47 PM
HickOverLOrd's Avatar
Dunno the difference between ingalls and weapon but I cant imagine that much of a difference with performance. But if your thinking about mounts, I would stick with the TD unless you really want to get into racing. Ive read vibrations from the mounts are pretty intense but worth it when it comes to track time. Ive had my TD on for about a week. Its set at 12mm and keeps the wheels planted on my stage 2 car pretty well. Just my 2cents.
Old Dec 25, 2007 | 05:57 PM
Raven SS's Avatar
yea the engine mount and the tranny prothane bushings
Old Dec 25, 2007 | 06:03 PM
95cam86roc's Avatar
I have a TD. Think the tranny mounts would be worth the money?
Old Dec 25, 2007 | 06:05 PM
Raven SS's Avatar
yes very much so...
Old Dec 25, 2007 | 06:06 PM
95cam86roc's Avatar
Good! Thats what i wanted to hear... thanks!
Old Dec 25, 2007 | 09:07 PM
95cam86roc's Avatar
Well Raven... I ordered the tranny mounts after i talked to you on here earlier. I just hope they are fairly easy to install.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
Builttss
Oct 4, 2015 10:21 AM
Cptnslo
Sep 24, 2015 09:32 AM
