Torque Specs!!
Torque Specs!!
Well.. I just received some things and was wondering on some torque specs. Mostly on the SC Snout but any other torque specs would be great... This should probably be a sticky too!!! if everyone contributes
Fastener Tightening Specifications
A/C Compressor to Block Bolt
20 Nˇm
15 lb ft
Accessory Drive Belt Tensioner Bolt
32 Nˇm
24 lb ft
Balance Shaft Adjustable Chain Guide Bolt
10 Nˇm
89 lb in
Balance Shaft Bearing Carrier to Block Bolt
10 Nˇm
89 lb in
Balance Shaft Fixed Chain Guide Bolt
10 Nˇm
89 lb in
Balance Shaft Sprocket Bolt
50 Nˇm
37 lb ft
Baro Sensor and Coolant Return Line Assembly
8 Nˇm
71 lb in
Boost Solenoid Bracket Nut
10 Nˇm
89 lb in
Cam Cover to Cylinder Head Bolt
8 Nˇm
71 lb in
Cam Cover to Ground Cable Bolt
10 Nˇm
89 lb in
Cam Cover to Ground Cable Stud
10 Nˇm
89 lb in
Cam Sensor Bolt
8 Nˇm
71 lb in
Camshaft Position Sensor Housing Stud
22 Nˇm
16 lb ft
Camshaft Bearing Cap Bolt
10 Nˇm
89 lb in
Camshaft Sprocket Bolt
First Pass
85 Nˇm
63 lb ft
Final Pass
30 degrees
Camshaft Timing Chain Tensioner
75 Nˇm
55 lb ft
Chain Guide Access Hole Plug
90 Nˇm
59 lb ft
Connecting Rod Bolts
First Pass
25 Nˇm
18 lb ft
Final Pass
100 degrees
Crankshaft Bearing Lower Crankcase to Block Bolts
First Pass
20 Nˇm
15 lb ft
Final Pass
70 degrees
Crankshaft Position Sensor Bolt
8 Nˇm
71 lb in
Crankshaft Position Sensor Housing Studs
22 Nˇm
16 lb ft
Crankshaft Pulley Bolt
First Pass
100 Nˇm
74 lb ft
Final Pass
75 degrees
Cylinder Head Bolt
First Pass
30 Nˇm
22 lb ft
Final Pass
155 degrees
Cylinder Head Front Chaincase Bolt
35 Nˇm
26 lb ft
Cylinder Head Oil Gallery Plug
35 Nˇm
26 lb ft
Dipstick Guide to Intake Manifold Bolt
10 Nˇm
89 lb in
Elek. ICM Cover Bolt
8 Nˇm
71 lb in
Engine Coolant Temperature Sensor
22 Nˇm
16 lb ft
Engine Lift Bracket Front Bolt
25 Nˇm
18 lb ft
Engine Lift Bracket Rear Bolt
25 Nˇm
18 lb ft
Engine Mount Intermediate Bracket Bolts
100 Nˇm
74 lb ft
Engine Mount to Intermediate Bracket Bolts
50 Nˇm
37 lb ft
Engine Mount to Mid-Rail Nuts
100 Nˇm
74 lb ft
Exhaust Manifold to Cylinder Head Nut
12 Nˇm
106 lb in
Exhaust Manifold to Cylinder Head Stud
10 Nˇm
89 lb in
Exhaust Manifold Pipe Flange Stud
16 Nˇm
12 lb ft
Exhaust Takedown Pipe Nuts
30 Nˇm
22 lb ft
Flywheel (SMT) Bolt
First Pass
53 Nˇm
39 lb ft
Final Pass
25 degrees
Frame Bolts
First Pass
100 Nˇm
74 lb ft
Second Pass
180 degrees
Front Cover to Block Bolt
25 Nˇm
18 lb ft
Front Lift Bracket Bolt
25 Nˇm
18 lb ft
Fuel Feed Line
14 Nˇm
124 lb in
Fuel Feed Line and Injector Harness Bracket
10 Nˇm
89 lb in
Fuel Line Bracket Bolt
10 Nˇm
89 lb in
Fuel Pipe Bracket Bolt
10 Nˇm
89 lb in
Fuel Rail Bracket Stud
10 Nˇm
89 lb in
Generator Bracket Bolt
42 Nˇm
31 lb ft
Generator Connector Nut
20 Nˇm
15 lb ft
Generator to Block Bolt
20 Nˇm
15 lb ft
Heat Shield to Exhaust Manifold Bolt
23 Nˇm
17 lb ft
Idler Pulley
22 Nˇm
16 lb ft
Ignition Coil Bolt
8 Nˇm
71 lb in
Intake Camshaft Rear Cap Bolt
25 Nˇm
18 lb ft
Intake Manifold to Cylinder Head Bolt
22 Nˇm
16 lb ft
Intake Manifold to Cylinder Head Nut
22 Nˇm
16 lb ft
Intake Manifold to Cylinder Head Stud
6 Nˇm
53 lb in
Knock Sensor Bolt
25 Nˇm
18 lb ft
Lower Crankcase to Block Peripheral Bolts
25 Nˇm
18 lb ft
Oil Bypass Tube
22 Nˇm
16 lb ft
Oil Cooler
22 Nˇm
16 lb ft
Oil Filter Housing Cover
25 Nˇm
18 lb ft
Oil Gallery Plug
35 Nˇm
26 lb ft
Oil Gallery Plug - Rear
60 Nˇm
44 lb ft
Oil Level Indicator Tube Bolt
10 Nˇm
89 lb in
Oil Pan Drain Plug
25 Nˇm
18 lb ft
Oil Pan to Block Bolts
25 Nˇm
18 lb ft
Oil Pressure Sensor
18 Nˇm
13 lb ft
Oil Pump Gerotor Cover Bolt
6 Nˇm
53 lb in
Oil Pump Pressure Relief Valve Plug
40 Nˇm
30 lb ft
Oxygen Sensor
42 Nˇm
31 lb ft
Power Steering Pump Blockout Plate Bolts
25 Nˇm
18 lb ft
Rear Lift Bracket Bolt
22 Nˇm
16 lb ft
Spark Plug
20 Nˇm
15 lb ft
Starter Motor to Block Bolt
40 Nˇm
30 lb ft
Starter Terminal Nut
17 Nˇm
13 lb ft
Supercharger Bolts
25 Nˇm
18 lb ft
Thermostat Housing to Block Bolts
10 Nˇm
89 lb in
Throttle Body Bolt
10 Nˇm
89 lb in
Timing Chain Adjustable Guide Bolt
10 Nˇm
89 lb in
Timing Chain Fixed Guide Bolt
10 Nˇm
89 lb in
Timing Chain Oil Nozzle Bolt
10 Nˇm
89 lb in
Timing Chain Upper Guide Bolt
10 Nˇm
89 lb in
Torque Converter Bolts
62 Nˇm
46 lb ft
Transmission to Engine Bolts
75 Nˇm
55 lb ft
Vent Tube to Cylinder Head
15 Nˇm
11 lb ft
Water Pipe Support Bracket Bolt
10 Nˇm
89 lb in
Water Pump Access Cover Bolt
7 Nˇm
62 lb in
Water Pump/Balance Shaft Chain Tensioner Bolt
10 Nˇm
89 lb in
Water Pump Bolts
25 Nˇm
18 lb ft
Water Pump Drain Plug
20 Nˇm
15 lb ft
Water Pump Sprocket Bolt
10 Nˇm
89 lb in
20 Nˇm
15 lb ft
32 Nˇm
24 lb ft
10 Nˇm
89 lb in
10 Nˇm
89 lb in
10 Nˇm
89 lb in
50 Nˇm
37 lb ft
8 Nˇm
71 lb in
10 Nˇm
89 lb in
8 Nˇm
71 lb in
10 Nˇm
89 lb in
10 Nˇm
89 lb in
Cam Sensor Bolt
8 Nˇm
71 lb in
22 Nˇm
16 lb ft
10 Nˇm
89 lb in
First Pass
85 Nˇm
63 lb ft
Final Pass
30 degrees
75 Nˇm
55 lb ft
90 Nˇm
59 lb ft
First Pass
25 Nˇm
18 lb ft
Final Pass
100 degrees
First Pass
20 Nˇm
15 lb ft
Final Pass
70 degrees
8 Nˇm
71 lb in
22 Nˇm
16 lb ft
First Pass
100 Nˇm
74 lb ft
Final Pass
75 degrees
Cylinder Head Bolt
First Pass
30 Nˇm
22 lb ft
Final Pass
155 degrees
35 Nˇm
26 lb ft
35 Nˇm
26 lb ft
10 Nˇm
89 lb in
8 Nˇm
71 lb in
22 Nˇm
16 lb ft
25 Nˇm
18 lb ft
25 Nˇm
18 lb ft
100 Nˇm
74 lb ft
50 Nˇm
37 lb ft
100 Nˇm
74 lb ft
12 Nˇm
106 lb in
10 Nˇm
89 lb in
16 Nˇm
12 lb ft
30 Nˇm
22 lb ft
Flywheel (SMT) Bolt
First Pass
53 Nˇm
39 lb ft
Final Pass
25 degrees
Frame Bolts
First Pass
100 Nˇm
74 lb ft
Second Pass
180 degrees
25 Nˇm
18 lb ft
25 Nˇm
18 lb ft
Fuel Feed Line
14 Nˇm
124 lb in
10 Nˇm
89 lb in
10 Nˇm
89 lb in
10 Nˇm
89 lb in
10 Nˇm
89 lb in
42 Nˇm
31 lb ft
20 Nˇm
15 lb ft
20 Nˇm
15 lb ft
23 Nˇm
17 lb ft
Idler Pulley
22 Nˇm
16 lb ft
Ignition Coil Bolt
8 Nˇm
71 lb in
25 Nˇm
18 lb ft
22 Nˇm
16 lb ft
22 Nˇm
16 lb ft
6 Nˇm
53 lb in
Knock Sensor Bolt
25 Nˇm
18 lb ft
25 Nˇm
18 lb ft
Oil Bypass Tube
22 Nˇm
16 lb ft
Oil Cooler
22 Nˇm
16 lb ft
25 Nˇm
18 lb ft
Oil Gallery Plug
35 Nˇm
26 lb ft
60 Nˇm
44 lb ft
10 Nˇm
89 lb in
Oil Pan Drain Plug
25 Nˇm
18 lb ft
25 Nˇm
18 lb ft
Oil Pressure Sensor
18 Nˇm
13 lb ft
6 Nˇm
53 lb in
40 Nˇm
30 lb ft
Oxygen Sensor
42 Nˇm
31 lb ft
25 Nˇm
18 lb ft
22 Nˇm
16 lb ft
Spark Plug
20 Nˇm
15 lb ft
40 Nˇm
30 lb ft
17 Nˇm
13 lb ft
Supercharger Bolts
25 Nˇm
18 lb ft
10 Nˇm
89 lb in
Throttle Body Bolt
10 Nˇm
89 lb in
10 Nˇm
89 lb in
10 Nˇm
89 lb in
10 Nˇm
89 lb in
10 Nˇm
89 lb in
62 Nˇm
46 lb ft
75 Nˇm
55 lb ft
15 Nˇm
11 lb ft
10 Nˇm
89 lb in
7 Nˇm
62 lb in
10 Nˇm
89 lb in
Water Pump Bolts
25 Nˇm
18 lb ft
20 Nˇm
15 lb ft
10 Nˇm
89 lb in
Originally Posted by djt81185
This is actually the link I also provided. There is lots of great info there. I forget who actually put it up though.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
