Ultra-Gauge Installed
It's a problem for all ultragauges. They have a write up on how to fix it on their website. Display garbled on page change
Maybe it's because I customized multiple pages? Idk
"The following applies to all UltraGauge EM with a version date prior to 10/1/12."
I just bought mine.. so maybe this issue was updated?
from when i searched 2006 cobalt ss/sc...
Vehicle Matches: 1
Vehicle #1
Manufacture Date: 10/2005
Transmission: Manual
Protocol: J1850 VPM
Open/Closed Loop Emissions Status
Percent Engine Load
Engine coolant temperature (F)
Engine coolant temperature (C)
Short Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 1
Intake Manifold Absolute Pressure (MAP) PSI
Intake Manifold Absolute Pressure (MAP)(kPa)
RPM
MPH
KPH
Ignition Timing Advance
Intake Air Temperature (F)
Intake Air Temperature (C)
Mass Air Flow Sensor output in grams/sec
Absolute Throttle Position Percentage
Bank 1 Oxygen Sensor 1 Voltage
Bank 1 Oxygen Sensor 2 Voltage
Distance traveled with Check Engine Light on (miles)
Distance traveled with Check Engine Light on (km)
Boost Pressure, (Relative Pressure) (PSI)
Boost Pressure, (Relative Pressure) (kPa)
Brake Horsepower 1
Brake Kilowatts 1
Torque 1 (ft lbs)
Torque 1 (N.m)
Brake Horsepower 2
Brake Kilowatts 2
Torque 2 (ft lbs)
Torque 2 (N.m)
Volumetric Efficiency
UG Battery voltage
Mass Air Flow 2, Calibrated/Calculated
Instantaneous MPG
Intantaneous Gallons/Hour (GPH)
Instantaneous KPL
Intantaneous Liters/Hour
Instantaneous L/100km
Distance to Empty(DTE)(miles)
Distance to Empty(DTE)(km)
Time to Empty (TTE)
Fuel Level (gallons)
Fuel Level (liters)
Oil Distance(miles)
Oil Distance(km)
Service Distance(miles)
Service Distance(km)
General Purpose
Average MPH
Average MPG
Average Gallon/Hour (GPH)
Fuel Used (gallons)
Run Time
Distance (miles)
Average KPL
Average L/100km
Average KPH
Average Liters/Hour
Fuel Used (liters)
Distance (km)
TRIP GAUGES
Run Time
Average MPH
Average MPG
Fuel Used Gallons
Average Gallon Per Hour (GPH)
UltraGauge Internal Temperature (F)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
UltraGauge Internal Temperature (C)
SHORT TRIP GAUGES
Run Time
Avergage MPG
Fuel Used (gallons)
Average gallons/hour
Average MPH
Distance (miles)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
Vehicle Matches: 1
Vehicle #1
Protocol: J1850 VPM
Percent Engine Load
RPM
MPH
KPH
Brake Horsepower 1
Brake Kilowatts 1
Torque 1 (ft lbs)
Torque 1 (N.m)
Brake Horsepower 2
Brake Kilowatts 2
Torque 2 (ft lbs)
Torque 2 (N.m)
UG Battery voltage
Instantaneous MPG
Instantaneous KPL
Time to Empty (TTE)
Fuel Level (liters)
Oil Distance(miles)
Oil Distance(km)
General Purpose
Average MPH
Average MPG
Fuel Used (gallons)
Run Time
Distance (miles)
Average KPL
Average L/100km
Average KPH
Average Liters/Hour
Fuel Used (liters)
Distance (km)
TRIP GAUGES
Run Time
Average MPH
Average MPG
Fuel Used Gallons
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
SHORT TRIP GAUGES
Run Time
Avergage MPG
Fuel Used (gallons)
Average MPH
Distance (miles)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
I've had mine for the longest time.
I've introduced it to the forum a while back(last year or longer ago) never really did get that much excitement from everyone. I have the 2.5bar lsj map sensor on my car and read IAT2 instead of IAT1s. I have mine set to read timing advance since it cant read KR on my LE5. I love this thing its helped me troubleshoot issues with my car and fix them asap.
cuz its an obd2 reader just like the interceptor, so if the interceptor reads iat2 then so should this one right?
Have mine in my A pillar
http://www.flickr.com/photos/keiserx13/6855645086/http://www.flickr.com/photos/keiserx13/6855645086/ by http://www.flickr.com/people/keiserx13/, on Flickr
I guess the price went up.. Ive had one for RPM's in my ranger before i swapped to a with tach cluster and i only paid 65$! Lol It's a neat gauge for sure! But i also have a code reader in my truck at all times! I got sick of the fuel mileage beeping when i had allready put gas in/reset the parameter. Lol but then again i could go from 20+ MPG instant to about 6 if i floored it! Damn heavy ranger with a 3.slo Flex fuel with 24lb/hr injectors!!
So today i was messing with the ultra gauge i noticed a few thing. After install my display started flashing power steering and when driving my rpm and mph gauges started to not work at all they would come on and off. Did anyone else have this problem?
found it best to plug the gauge in with the car ON
