Ultra-Gauge Installed
Old Nov 5, 2012 | 01:58 PM
padlock's Avatar
Originally Posted by SSScott
It's a problem for all ultragauges. They have a write up on how to fix it on their website. Display garbled on page change
Maybe it's because I customized multiple pages? Idk
quoted from article
"The following applies to all UltraGauge EM with a version date prior to 10/1/12."
I just bought mine.. so maybe this issue was updated?
Old Nov 5, 2012 | 02:01 PM
06cobalt racer's Avatar
from when i searched 2006 cobalt ss/sc...
Vehicle Matches: 1
Vehicle #1
Manufacture Date: 10/2005
Transmission: Manual
Protocol: J1850 VPM
Open/Closed Loop Emissions Status
Percent Engine Load
Engine coolant temperature (F)
Engine coolant temperature (C)
Short Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 1
Intake Manifold Absolute Pressure (MAP) PSI
Intake Manifold Absolute Pressure (MAP)(kPa)
RPM
MPH
KPH
Ignition Timing Advance
Intake Air Temperature (F)
Intake Air Temperature (C)
Mass Air Flow Sensor output in grams/sec
Absolute Throttle Position Percentage
Bank 1 Oxygen Sensor 1 Voltage
Bank 1 Oxygen Sensor 2 Voltage
Distance traveled with Check Engine Light on (miles)
Distance traveled with Check Engine Light on (km)
Boost Pressure, (Relative Pressure) (PSI)
Boost Pressure, (Relative Pressure) (kPa)
Brake Horsepower 1
Brake Kilowatts 1
Torque 1 (ft lbs)
Torque 1 (N.m)
Brake Horsepower 2
Brake Kilowatts 2
Torque 2 (ft lbs)
Torque 2 (N.m)
Volumetric Efficiency
UG Battery voltage
Mass Air Flow 2, Calibrated/Calculated
Instantaneous MPG
Intantaneous Gallons/Hour (GPH)
Instantaneous KPL
Intantaneous Liters/Hour
Instantaneous L/100km
Distance to Empty(DTE)(miles)
Distance to Empty(DTE)(km)
Time to Empty (TTE)
Fuel Level (gallons)
Fuel Level (liters)
Oil Distance(miles)
Oil Distance(km)
Service Distance(miles)
Service Distance(km)
General Purpose
Average MPH
Average MPG
Average Gallon/Hour (GPH)
Fuel Used (gallons)
Run Time
Distance (miles)
Average KPL
Average L/100km
Average KPH
Average Liters/Hour
Fuel Used (liters)
Distance (km)
TRIP GAUGES
Run Time
Average MPH
Average MPG
Fuel Used Gallons
Average Gallon Per Hour (GPH)
UltraGauge Internal Temperature (F)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
UltraGauge Internal Temperature (C)
SHORT TRIP GAUGES
Run Time
Avergage MPG
Fuel Used (gallons)
Average gallons/hour
Average MPH
Distance (miles)
Average KPH
Avergage KPL
Avergage L/100km
Liters Used
Average Liters/Hour
Distance (km)
Old Nov 5, 2012 | 02:04 PM
SSScott's Avatar
Originally Posted by padlock
quoted from article
That would be the reason. I wonder if I can update mine. I will look into that.
Old Nov 7, 2012 | 05:29 PM
Thedomsaww's Avatar
sO THIS WILL WORK ON THE LSJ YA?
Old Nov 7, 2012 | 06:55 PM
Gelladuga69's Avatar
Very interested. Sub'd
Old Nov 7, 2012 | 07:44 PM
bratboy90's Avatar
Bumping to find out if anyone with a LSJ has found out if it will shot IAT2's or KR...
Thanks! Sub'd.
Old Nov 7, 2012 | 08:52 PM
Dragonsfire12345's Avatar
I've had mine for the longest time.
I've introduced it to the forum a while back(last year or longer ago) never really did get that much excitement from everyone. I have the 2.5bar lsj map sensor on my car and read IAT2 instead of IAT1s. I have mine set to read timing advance since it cant read KR on my LE5. I love this thing its helped me troubleshoot issues with my car and fix them asap.
Old Nov 16, 2012 | 04:13 PM
Thedomsaww's Avatar
sorry just a bit confused does this (ultra gauge) read iat2?
cuz its an obd2 reader just like the interceptor, so if the interceptor reads iat2 then so should this one right?
Old Nov 16, 2012 | 05:17 PM
bratboy90's Avatar
Add my note...Does it read IAT2 on a LSJ...Not a LNF.
Old Nov 16, 2012 | 05:27 PM
Murdered SS's Avatar
Where would i be able to purchase one of these so called ultra gauge?
Old Nov 16, 2012 | 09:36 PM
  #36
veilside's Avatar
UltraGauge Automotive Information Center and OBDII Scan Tool
Old Nov 16, 2012 | 09:37 PM
  #37
veilside's Avatar
Just received it. Great thing for the price. Will try it more tomorrow when my gauge support is dryed (just painted it) and will go for a ride!
Old Nov 16, 2012 | 09:42 PM
  #38
serega12's Avatar
Looks nice. Almost makes me want to dig out my scan gauge II out in the garage (there from my other previous cars) and install it for the extra info.
Old Nov 16, 2012 | 11:08 PM
  #39
Just ordered mine today. Cant wait to install
Old Nov 16, 2012 | 11:10 PM
  #40
keiserX13's Avatar
Have mine in my A pillar
http://www.flickr.com/photos/keiserx13/6855645086/http://www.flickr.com/photos/keiserx13/6855645086/ by http://www.flickr.com/people/keiserx13/, on Flickr
Old Nov 16, 2012 | 11:18 PM
  #41
Bluelightning's Avatar
Got Bewst?
Hmmmmm I like the audable beep function. I wouldn't have to keep my interceptor in the corner of my eye for the leds to light up for knock.
Old Nov 17, 2012 | 02:49 AM
  #42
padlock's Avatar
as of now.. i cant read knock.. one downfall that I have found with this gauge.. only one as of yet too
Old Nov 17, 2012 | 03:25 AM
  #43
thedubsack85's Avatar
I guess the price went up.. Ive had one for RPM's in my ranger before i swapped to a with tach cluster and i only paid 65$! Lol It's a neat gauge for sure! But i also have a code reader in my truck at all times! I got sick of the fuel mileage beeping when i had allready put gas in/reset the parameter. Lol but then again i could go from 20+ MPG instant to about 6 if i floored it! Damn heavy ranger with a 3.slo Flex fuel with 24lb/hr injectors!!
Old Nov 17, 2012 | 04:32 PM
  #44
bratboy90's Avatar
Being you have an SS/SC let me know if you can see IAT2's. I have yet to get a definitive answer....
Old Nov 22, 2012 | 03:52 AM
  #45
I got mine today its pretty good just need to figure out what keep on the display.
Old Nov 22, 2012 | 07:13 PM
  #46
So today i was messing with the ultra gauge i noticed a few thing. After install my display started flashing power steering and when driving my rpm and mph gauges started to not work at all they would come on and off. Did anyone else have this problem?
Old Nov 22, 2012 | 10:30 PM
  #47
keiserX13's Avatar
i did
found it best to plug the gauge in with the car ON
Old Nov 22, 2012 | 10:45 PM
  #48
Wert842's Avatar
Very nice. I like what all this thing can do.
So it can't detect knock on an LNF?
Old Nov 23, 2012 | 04:50 PM
  #49
Ok i got it working correctly now this thing is awesome and for the price even better lol
Old Dec 6, 2012 | 08:33 PM
  #50
Wert842's Avatar
Did anyone get it to detect knock on an LNF yet? Does it detect AFR accordingly too? Also, any other flaws?
