Under car heat shield removal
do you realize how hot an exhaust gets? there's a reason it's there.
Sorry i should have been more clear,trying to find out where a rattling noise is coming from and want to know if thats whats causing it,i checked my whole exhaust system and the heat shield and didn't find anything so i don't know.
Did you try tapping on your exhaust pipe with a rubber mallet? Usually that's how I narrow down an exhaust rattle..
What kind of rattle are you looking for and when does it happen? Where does it sound like its coming from?
With that info I can give you places to look.
I did not lift the car yet, so maybe there is a way to reach the top bolts that i did not see?
Does anyone have the solution to this problem? How to fix this rattle?
Also, as i have read in the above posts the heat shield should probably not be removed? What would happen if it was?
Yes this is the same heat shield I am having problems with. It's loose and is rattling, especially on cold start. I looked at them momentarily, and it looks like in order to tighten/remove the shield you have to somehow get to the top bolts (because the bottom nuts are round and can not be gripped). I can't see how this is done without disassembling a little more than I'd like to.
If you remove the heatshield you're oging to transfer alot of heat to the floor of the car. It may or may not cause issues but I'd rather not risk it.
Yea, but it looks like it is held on with bolts that may be able to be tightened? Like i said previously, i can only see the bottom of the bolts, with the round nuts and a thread coming through them.
Just wondering if anyone knows if these can be tightened/removed to stop the rattling?
I was thinking to just add on some small hex nuts to the botttoms of the round ones to tighten the bolts/heat shield, if i can not get the round ones off.
Getaway_Driver
09-08-2015 09:41 AM
