View Poll Results: Do you get your car undercoated for the winter?
Yes
20.83%
No
45.83%
Car is stored for the winter
33.33%
Voters: 24. You may not vote on this poll
Undercoat
Old Nov 11, 2012 | 07:39 PM
Undercoat
Anybody get their car undercoated for the winter?
Old Nov 11, 2012 | 07:48 PM
Who Gee's Avatar
buying the so called under coating is a big scam for dealersa to screw you out of money new cars do not need it.
Old Nov 11, 2012 | 07:50 PM
Gunney_07's Avatar
dear god what?
Old Nov 11, 2012 | 08:07 PM
BlueStang's Avatar
You'll have to excuse him, he's from Qubec
Old Nov 11, 2012 | 08:09 PM
dieGone's Avatar
Old Nov 11, 2012 | 08:19 PM
Bass_Waves's Avatar
theres a such thing ? o my. the only undercoat i know is salt
Old Nov 11, 2012 | 08:35 PM
No, he moved there lol
Oh noes
Old Nov 11, 2012 | 09:44 PM
Gunney_07's Avatar
that is why i store mine and drive my jeep
Old Nov 11, 2012 | 09:49 PM
Its un needed. my car has been through new england winters since 06, i bought my car to drive it daily. No rust issues.
Old Nov 11, 2012 | 09:56 PM
Powell Race Parts's Avatar
cobalt bodies underneath are two sided zinc phosphate dipped and stand up well. the cradles and twisiting beams, the steel control arms on ls lt and the struts dont. in rust belt areas, a rust preventative oiling (Krown, rust check) etc is a good idea.
The captive nuts for the cradle at the front and the twisting beam at the rear rust horribly so anti rust coating up there is good too.
I dont drive my Delta in the winter. My wntrbtr2 is rust proofed with this special oiling product each winter. It drips for a few days a massive pita but it sure takes care of rust. A good applicator will also spray the anti rust stuff in the bumper/fender seams and the bottom of the doors, places Delta's love to rust.
Old Nov 11, 2012 | 10:38 PM
Yeah, I don't plan on getting it done. Run it through a couple car washes that spray underneath that's about it.
Old Nov 11, 2012 | 11:45 PM
2.2balt's Avatar
I've had my car sprayed with Rust Check every year since I bought it and its mint after 4 winters. The salt used up here in Ottawa is crazy, so without it the underside would be crusty already. As John said, the areas that will bubble and rust first are the door bottoms (especially since the paint on the bottom edge of the door wears off due to contact with that rubber seal on the door sill), and the front hood seam (there is no seam sealer from the factory).
On the underside, all the suspension components and cradle will rust quickly. The actual underside of the body isn't bad, but its everything else that goes.
Old Nov 12, 2012 | 12:10 AM
Pinky Demon's Avatar
Absolutely, and anyone who says otherwise is a fool and has never owned cars long term in the rust belt. If you see salt and brine, you need to do it. I will be shooting my undercarriage with POR-15 and the topping off with Fluid Film. If you don't have access to painting equipment, I would just recommend scrubbing the underbody clean, and then following with Fluid Film in a spray can. I suggest you look up Fluid Film as it is quite legendary in the Snow and Ice industry. It is sold at most John Deere Equipment dealerships.
My background in this is I work in the Snow and Ice industry, and am constantly fighting rust on my trucks.
Old Nov 12, 2012 | 12:12 AM
Any body ever try bed liner on the bottom of their doors? I think I'm going to try it.
Old Nov 12, 2012 | 03:40 AM
EXsoccer1921's Avatar
whats winter?
Old Nov 12, 2012 | 03:55 AM
Squints's Avatar
whats winter?
about 50* for you and me lol
Old Nov 12, 2012 | 08:26 AM
2.2balt's Avatar
I wouldn't. It will probably plug the drainage holes in the bottom of the doors, promoting further rust/corrosion.
I used a few strips of 3M clearbra (the **** you'd normally put on the front of the car) which I put on the very bottom edge (the part of the door skin that is like folded around the bottom of the door), but not covering the upper edge (if that makes any sense lol). Works mint. Need to put new pieces on though as stuff has managed to get in there, but it was good for a couple years I'd say.
Old Nov 12, 2012 | 08:51 AM
Wouldn't a decent, thick undercoat help reduce road noise though? i've thought of getting one just for that reason
Old Nov 12, 2012 | 09:39 AM
BlueStang's Avatar
when I bought my car the dealer tried to sell me a $800 under coating and scotch guarding package, I asked him what he was smoking
Old Nov 12, 2012 | 10:18 AM
StevoElSupremo's Avatar
well.. I owned a 1990 cavalier, and he had rustCheck stickers in the owners manual from 1991.. and there wasn't a SPOT of rust on that car.
Old Nov 12, 2012 | 10:27 AM
Mindrot's Avatar
I'm having a rush issue at the edge of my hood. Where the metal folded over making the edge of it rounded. Somehow water got up in there and now I have a rust bubble. Has this happened to anyone else?
Old Nov 12, 2012 | 07:57 PM
2.2balt's Avatar
Its common. Its because there is no seam sealer. Water gets in there and sits in the edge then it bubbles and comes around. Rust Check would solve that, as it expels moisture thus protecting the inner seam...though its too late now. Go to a body shop lol
I would advise against any type of thick tar undercoating as it WILL dry out, crack, let moisture in, then rot the car faster.
Rust Check ftw
Old Nov 12, 2012 | 08:16 PM
Omnigear's Avatar
plastidip
Old Nov 12, 2012 | 11:57 PM
whats winter?
Come out east, we'll show you lol
Just turn the tunes up
Me too, plus a whole bunch of other garbage.
Originally Posted by Omnigear
plastidip
Guy at work used that Rust-Oleum you use on grills on his POS Tacoma that was rusted out underneath. Neither is coming near mine.
SSlobalt55
Oct 10, 2014 07:11 PM
Redspire
Sep 5, 2014 08:48 AM
FryLoch
Sep 22, 2011 08:15 AM
erics95se
Jun 25, 2011 10:33 AM
jkenosky88
Wheels and Tires
13
Jun 3, 2010 01:01 AM
