use the same sensors
got a question , I took the s/c off of my le5 and trying to get it back to stock but my wiring harness is set up for a 2.5 map and the stock manifold is a 3 wire map sensor can I just use the 3wires from the map and dead end the other 2that where for the temp? and does the maf have to change also? I want to get it running na first and then put the s/c back on if the motor is any good, motor was giving to me its under 60000 miles on it . I had the s/c on it but after cleaning the lam--- what ever theyre called, in the intake when I put it back together I guess I pinched an "O" ring and it leaked water into the motor, luckily never got the motor running before I found it.
thanks for any and all help
Garrettsi
Feb 14, 2014 03:34 PM
