Valve cover bolts pattern
I criss-cross starting from the middle and work my way outwards.
Remember 89inlbs is almost nothing.
FWIW, I just installed an intake plenum spacer on a VQ35, and the torque spec is incredibly low on those two, so low that the maker of the spacer actually recommended using a socket driver (looks like a screwdriver handle) instead of a socket wrench to ensure that you don't over torque it.
No pattern specified, but if you start at the middle and work radially all the way out you will be set.
I've installed many leak free lsj valve covers in my time.
