water in door
Old Oct 23, 2009 | 03:11 PM
red2006 ls's Avatar
water in door
i have read that on the doors on the cobalts collect water in the bottom of the door i pulled off my door panel and it had water in it is there a way to stop this from happening again
Old Oct 24, 2009 | 11:55 PM
shawn672's Avatar
never heard of this or seen this in any of my 3 cobalts over the past 3 years... /shrug
Old Oct 24, 2009 | 11:57 PM
thedude411's Avatar
ughhh i hope this isnt a common occurrence as i have sum very expensive JL audio speakers sitting on my desk waiting for me to get money to get them installed...
Old Oct 24, 2009 | 11:59 PM
PsychoCam's Avatar
about 2 months ago I took my door panel off to put tc door panels in and there was water in the inside of my door also. YA the doors collect a lot of moistue and water in the door
Old Oct 25, 2009 | 12:24 AM
BlueStang's Avatar
It's seems to never end the problems with these cars
Old Oct 25, 2009 | 01:30 AM
bluecobaltss06's Avatar
there should be small drains in the bottom of the door. little wholes. its normal for the doors to get water in them. thats what that large clear plastic piece is for thats stuck on behind the door panel. those drains might be plugged with debris. see if they are.
Old Oct 25, 2009 | 04:52 PM
Red07SSNA's Avatar
^^^You hit the "nail-on-the-head"! Clean out your drain holes -- that's the only reason water will collect in the door. Should make it a habit to look at the drains after cleaning/washing your car.
Old Oct 26, 2009 | 09:06 AM
red2006 ls's Avatar
does any one know y the water gets in the door in thd first place
Old Oct 26, 2009 | 09:26 AM
Illini_06SS's Avatar
All car doors are "wet" meaning they're designed to have some water get inside of them. No matter what you do, if you have a sliding window (as almost all cars do these days), water will leak through past the seal, and it will pour into the door at the ends of the seal. It's important that there is proper drainage of the water inside the door and that the inner door is well-coated with e-coat primer to prevent rust from this water. Everything I've seen about our doors suggest that the primer and paint has pretty good coverage.
Source: I'm a door designer.
Sean Cummings
Jan 8, 2020 10:17 AM
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
nathan112i
Sep 30, 2015 07:12 PM
Slick_Nick
Sep 28, 2015 09:15 PM
