water pump (not supercharger) question
Old Apr 18, 2018 | 01:33 AM
Sharkey's Avatar
got a quick question, is the impeller in the oem water pump steel or plastic?
im having a cooling issue with my ecotec swapped 944 that acts like a slipping water pump impeller
Old Apr 18, 2018 | 09:26 AM
exninja's Avatar
Steel
Old Apr 18, 2018 | 11:31 AM
They can be both. From my experience, older ones were plastic and newer ones were steel. Ive only ever had one steel one.
Old Apr 18, 2018 | 12:47 PM
exninja's Avatar
good thing i'm hanging on to my steel pump from my crappy LNF
Old Apr 18, 2018 | 12:55 PM
Sharkey's Avatar
that would make sense then. the engine was originally an 04 cavalier l61, and i know its an original pump, so its likely a plastic impeller then.
for the record, car is acting like it has low coolant flow at lower rpm. temps will just keep climbing while cruising, drop a couple gears and get the rpm up and itll drop right to 180*f within a few seconds. im suspecting the impeller is slipping on the shaft.
Old Apr 18, 2018 | 12:57 PM
exninja's Avatar
sorry i assumed. i thought it was just the germans that did silly things like plastic water pump impellers
Old Apr 18, 2018 | 03:47 PM
Sharkey's Avatar
well, the ecotec is partly saab, so kinda sorta explains it lol.
i pulled it apart, and the impeller is in fact plastic, but there is also nothing wrong with it.
Old Apr 18, 2018 | 03:52 PM
exninja's Avatar
mostly Opel (esp the early ones) so yeah it does make sense
Sean Cummings
Jan 8, 2020 10:17 AM
BEnSonn
Apr 9, 2017 04:24 PM
Blackguyver
Jul 22, 2011 12:31 AM
firepinch
Aug 10, 2009 09:22 AM
Brian's07SS
Jul 19, 2007 12:24 AM
