welp changed my mind lol
So after buying a m62 and intake mani, I changed my mind and want to turbo lol
So now gotta sell my parts and work on putting a turbo kit together or just buying a turbo kit from zzp for my 2.4l
what are your guys thoughts Lol? I made the right decision huh.
Depends on how you look at it, if you are using can tunes, then yes, i guess its easy as pie, since most of you guys run zzp or trifecta can tunes. I'm talking about a custom tune using hptuners from scratch. The SC swap is as simple as changing a few tables in hptuners and wiring up the harness properly, turbo is much more complex, blow through or pull through maf setups, maf scaling, modding of an LK9 manifold to fit onto the LE5 because you cant use the plastic manifold, much more to consider with a turbo kit.
