What to do for storage??
Old Oct 28, 2011 | 05:58 PM
robertmichaels's Avatar
Question What to do for storage??
so the time has come to put the Balt away.. this is my first car that i will be putting in storage for the winter, and was wondering what people would suggest doing.
Here is my list so far:
-remove battery
-fill gas tank and add stable
-(tires are junk) otherwise i would put them on wood to keep them off the concrete
-cover tail pipe
what else??
Old Oct 28, 2011 | 06:15 PM
BPacak's Avatar
Vtec Rep
i just fill up the tank and start it every now and then. and go for a little drive if its clean and dry.
Old Oct 28, 2011 | 06:21 PM
the only problem with that is the amount of salt they use around here, I could go around my block with a 5 gallon pail and it would be d**n near full when i got back to my place
Old Oct 28, 2011 | 06:24 PM
BPacak's Avatar
Vtec Rep
i mean you dont have to. i would just start it up and let it run for a little bit.
Old Oct 28, 2011 | 06:32 PM
CSA0890's Avatar
Its a Cobalt just drive it all winter lol
Old Oct 28, 2011 | 06:35 PM
BPacak's Avatar
Vtec Rep
makes me laugh when people say that.
Old Oct 28, 2011 | 06:54 PM
NWAE Cobalt's Avatar
Originally Posted by csa0890
its a cobalt just drive it all winter lol
qft!
Old Oct 28, 2011 | 06:58 PM
LS6Rally's Avatar
why so?
and when you start it make you you let it run up to normal operating temp, will help to no create condensation in the engine.
Old Oct 28, 2011 | 07:03 PM
BPacak's Avatar
Vtec Rep
Well i mean for me i still have my beater so i have no reason to drive mine in the winter.
1. save on insurance
2. save on gas
3. cant even boost in the winter
4. no rust
5. dont have to worry about getting in a accident
6. dont have to buy winter tires/rims
but if my beater dies, the balt will meat salt and snow haha
Old Oct 28, 2011 | 08:17 PM
this is why I have an audi s4 with ultra high perf all season tires....
SUCKAS...meet the snow hero lmao
Old Oct 28, 2011 | 08:29 PM
TommyP's Avatar
AWD > FWD
1. Change oil
2. Put a full, fresh tank of 93 in it
3. add recommended amount of stabilizer
4. drive it a bit to get stabilized fuel through the system.
5. Inflate tires to 40 psi
6. Remove battery, leave on trickle charger all winter
7. don't start it till you're ready to bring it out of storage
That's it. I did exactly this and had no issues when I started mine 5 months later in the spring.
Old Oct 28, 2011 | 10:34 PM
06_cobalt's Avatar
I'm not an expert on storing cars for the winter but why do you wanna park it on wood instead of concrete and why inflate the tires to 40 psi?
Old Oct 28, 2011 | 10:35 PM
BPacak's Avatar
Vtec Rep
so your tires dont get flat spots from sitting for so long. but ive left it as is for 2 winters and nothing happened to my tires.
Old Oct 28, 2011 | 10:36 PM
TommyP's Avatar
AWD > FWD
To keep tires from flat spotting, which you don't really NEED to worry about as modern tires SHOULD take their shape back after some movement. Pumping up the tires will help them keep their shape, plus should keep the pressure up to normal levels since cold air will make the air inside them condense and make the pressure drop.
Old Oct 29, 2011 | 06:44 AM
Growing up on a farm, the tractors that sat over winter (not put off the ground) got some seriouse flat spots where it made you bounce off the seats (at 25mph), and they stayed for a very long time...yes i know cars tires are much difforent and weigh less
as for the wood, concrete can get wet, the inside of the garage can get above freezing when the suns out causing the snow to melt at the door seam and could run into the garage and then when it freezes around your rear tires, not good
Old Oct 29, 2011 | 10:16 AM
CanadianCobalt's Avatar
Sitting on cement will take the moisture from the tires and dry rot them. Put a little piece of carpet underneath all 4 tires, put fuel stab in a full tank and run it through. Do an oil change, pull the battery and don't touch it till your ready to bring it out.
Joel
Old Oct 29, 2011 | 07:12 PM
06_cobalt's Avatar
Oh ok. Tells you how many times I've stored cars lol. And tommy as soon as I read that I felt dumb because I normally inflate my tires more in the winter. Not thinking ftl.
Old Nov 1, 2011 | 03:50 PM
shanenindy's Avatar
I have been storing 2 cars (cobalt&cobra) for the past 3 years for the winter months. Personally I just leave them on jack stands for the winter.. That takes the load off the tires and suspension. Just make sure you have a battery tender, fuel stabilizer, change the oil and I always take the time to check my coolant mixture.. Even though they are both inside. Now if your car is going to be outside and exposed you will need to take some more precautions
Old Nov 1, 2011 | 03:55 PM
outtamymind's Avatar
if your gonna be removing the battery out of the vehicle place it on a block of wood as well otherwise you will be needing a new battery come spring
Old Nov 1, 2011 | 03:58 PM
TommyP's Avatar
AWD > FWD
I just put mine in my bedroom closet with the charger on it.
Old Nov 1, 2011 | 04:00 PM
that works too, just as long as its not on concrete. some bad chemical reactions happen. can't remember what exactly but i know it kills your battery
Old Nov 2, 2011 | 12:31 AM
insylem's Avatar
Concrete is alkaline, where as your battery is acidic.
Somehow the "fumes" from the cement can get into the battery and cancel each other out.
At least that's what they taught us in school.
Old Nov 2, 2011 | 12:35 AM
ya i've been out of school for a long time and all i remembered was concrete + battery = bad lol
Old Nov 2, 2011 | 11:36 AM
be careful with that...the fumes from the battery charging could actually kill you...
Hill1513
Sep 21, 2015 07:18 AM
firishot34
Sep 5, 2015 01:09 PM
LaserBlue07SS
Apr 24, 2007 08:03 PM
Cobalt_SSTuner
Feb 25, 2007 11:13 AM
Ghalterman_usmc
Sep 11, 2006 11:45 PM
